Touchscreen IPS Monitor
mangafas
So can you suggest me a good IPS Touchscreen monitor up to 25 inches?
No money limited!
No money limited!
Hmm...that's a tough one. Will have to go in search of one, unless you wanna do that yourself? :)
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
I was thinking about this
LG 23ET63V
but i wanna now if is something better
Just to rule this out, have you tried Google searching for touch screen desktop monitors?
BTW, that LG one looks pretty good.
Yes but i also want it with IPS panel and there is nothing search
Okay, well you can either wait till later and I can see what I can find (because I need to go to sleep now as it's 3am here in Aus) or you can wait and see if anyone else can help you out. This is a pretty good community forum. I'm quite sure someone will help you out. :)
http://www.newegg.com/Product/Product.aspx?Item=9SIA4P01ZS4765 450$
is there a specific reason why you want to touchscreen monitor? Good IPS touch monitors are damn expensive
My current rig for entertainment/gaming: i5 4570 3,2GHz; MSI B85M-E45; ZOTAC GTX760 AMP!; 8GB (2x4GB) by Kingston; Seagate Barracuda 1TB 7200rpm; Corsair 200R, Corsair VS650; Dell U2312HM, Samsung DVD R/W optical drive; CM Devastator; Corsair MM400 gaming pad
