I recently build my system with the following specs:
1.Intel Core i7 4790k
2.NZXT Kraken x60 cooler
3.Asus Sabertooth z97 Mark 2
4.Corsair Vengeance 1600Mhz 16GB RAM
5.Asus Geforce 660Ti
6.Samsung EVO SSD 250GB
7.Corsair RM850 PSU
the CPU is fine in default settings idle temp is around 27 C and on load 64 C. But when I change to "Asus Optimal" settings in BIOS and try to load the CPU temp shoots up to 98 C. I don't know is it the problem of the mobo or am I doing something wrong  ?
https://linustechtips.com/topic/212017-4790k-overheating/
7.Corsair RM850 PSU
needs more thermal paste !!! huehue
https://linustechtips.com/topic/212017-4790k-overheating/#findComment-2877980
I have reapplied the thermal paste many times with Artic Alumina, re seated the cooler, checked the backplate still no luck :(
while i was joking its good that you already did that. what are the "asus optimised" setting ?. maybe its to much volt? or that the pump is failing when it gets to hot ?
https://linustechtips.com/topic/212017-4790k-overheating/#findComment-2878011
7.Corsair RM850 PSU
welcome to the Linus Tech Tips forums!
you have done nothing wrong, nor is there anything else wrong. what you are
seeing is a canned tune that tries to fit all with a high CPU voltage. you have
the cooler to make things better, but when you volt these platforms, they
produce heat and it sounds like you need to manually overclock, than rely on
a canned tune for overclocking. at least you know it is capable, just needs
better fine-tuning.
also stress-testing an "adaptive" mode (which it more than likely is) will produce
major heat and is spoken not to stress-test on adaptive mode.
https://linustechtips.com/topic/212017-4790k-overheating/#findComment-2878013
Realtemp shows voltage variation from 1.175 V to 1.325 V. At the peak volt cpu clock speed is at 4.6 Ghz.
https://linustechtips.com/topic/212017-4790k-overheating/#findComment-2878034
better fine-tuning.
I didn't understand what do you meant by canned tuning. I did try manual overclocking with only changing CPU V core Voltage to 1.275 V and CPU clock ratio to 47 on all cores resulting in 4.7 Ghz overclock with XMP profile changed to manual, i don't know what's the rest of the settings do in BIOS since I am coming from my core 2 Quad q6600 :)
https://linustechtips.com/topic/212017-4790k-overheating/#findComment-2878052
this is ASUS "Optimal" is a canned tune one-tune-fits all tuning. what are you using to
load/stress the CPU?
use this guide for overclocking: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
https://linustechtips.com/topic/212017-4790k-overheating/#findComment-2878070
WOW ! that's a good overclocking guide thanks a ton. I'll try this guide and report back to you.
https://linustechtips.com/topic/212017-4790k-overheating/#findComment-2878097
if that guide helps you, like the OP post.
Hi, I've been wondering about something. If I cleared CMOS while power was still connected to the board, that can cause damage correct? How would I fix this?
The most common result of insufficient wattage is a paperweight that looks like a PC
https://linustechtips.com/topic/212017-4790k-overheating/#findComment-2878214
@seiny
kinda depends on method used on CLR_CMOS.
yanking the battery while fully powered up could cause damage.
pressing the CLR_CMOS button while fully powered  really won't do much. all you
are doing is reverting back to a preprogrammed UEFI state. the current surge could
damage the file. so it is best practice to eliminate anything to corrupt the BIOS.
https://linustechtips.com/topic/212017-4790k-overheating/#findComment-2879262
@seiny
There is actually a problem I'm having, not exactly CMOS related but could you help please? I've been doing some research on the matter and haven't found any solid solution, may I pm you?
https://linustechtips.com/topic/212017-4790k-overheating/#findComment-2879323
