USB headers on board? Need more than 3!
Solved by xox,
You can get something called an internal USB hub. NZXT sells one.
http://www.legitreviews.com/nzxt-iu01-usb-2-0-internal-expansion-hub-review_1293
http://www.dailymotion.com/video/xo9iy0_nzxt-iu01-usb-header-expander-unboxing-first-look-linus-tech-tips_tech
You can also use a USB (outside) to header (inside) cable
Theminecraftaddict555 ·
Posted in Graphics Cards4 -
1
1
1
1
1
1
3
3
4
