Hello,
Greetings,
I am not able to connect my pc to the internet using ethernet but wifi on the pc works fine.I tried multiple cables but nothing changed then I plugged in my laptop to the same cable and it worked perfectly,so is my pc's ethernet port dead? or is there another problem?
Thank you.
https://linustechtips.com/topic/210074-ethernet-not-working/
try reinstalling the drivers. Usually this fixes the problem.
My System Specs: (Short list) i7 4770k, GTX 780, many SSD's, a 2 TB HDD(deceased :( ), Corsair 650D. Full list: http://pcpartpicker.com/user/kchriz6097/saved/8dh7YJ
Upgrade Plan: Acquire some Black Noctuas then add 16 or 32GB of 2133MHz memory
https://linustechtips.com/topic/210074-ethernet-not-working/#findComment-2851171
Try downloading the LAN drivers from the motherboard page.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/210074-ethernet-not-working/#findComment-2851175
Make sure your motherboard has the latest LAN drivers installed, and make sure your ethernet port is enabled under control panel > hardware and sound > devices and printers > device manager
There you should find your network controller, and make sure its enabled.
https://linustechtips.com/topic/210074-ethernet-not-working/#findComment-2851263
Have you verified the port on the other end?
Like he said it could be the ethernet ports on your Modem/Router make sure that you have a solid or blinking green light on the back if your Modem/Router had LED'S if not then i would recommend trying to test your PC with another Modem/Router to see if the problem still exists. If it's not that then we have to look at the possibility of it being a network issue with port's
https://linustechtips.com/topic/210074-ethernet-not-working/#findComment-2864351
