I've got a board coming that requires two CPU 8 pin power connectors, and i only have the one 8pin eps cable from my power suply. As far as i can find the pci-e ext power cables are keyed differently so won't work for me there, and any power supplies that have the two 8 pin CPU ones are amazingly expensive.
Is it possible to find molex to 8pin for the CPU?
Or would making use of the splitting nature on the eps 8 pin connector and using two 4pin to 8pin adapters work? Would doing that not draw too much current through the cables?
Cheers!
Desktop: i5 2500k @ 4.8GHz stable, 16GB Corsair XMS3, Asus P8P67, Corsair H50 AIO Liquid cooler (worst decision in the build), Corsair GS600, Intel 520 180GB, and to top it all off... An nvidia gt630!
Laptop: Dell Vostro 3360, i7 3517U, 8GB, 120GB Samsung 840 Evo, Intel 7260 Dual band AC, Dell 4G wireless modem
Workstation(in the making): Two Xeon X5650 processors (24 threads!), Supermicro X8DTE-F,56 GB ECC ram (more to come, a lot more), very old 'industrial computer' case, supermicro heatsinks (amazingly silent) and as for the rest, i've not bought it yet!
https://linustechtips.com/topic/209219-two-cpu-8-pin-connectors/
You don't need to have both plugged in, it's only for very serious overclockers.
CPU: i7 5820K 4.0GHz @1.15V | MOBO: Asus X99 Sabertooth | GPU: Gigabyte Windforce GTX 980Ti, LTT Orange | CASE: NZXT H440 Black 2015 | COOLER: Noctua NH-D15S w/ LTT Fans | RAM: 32GB Patriot 3000MHz | STORAGE: 512GB Samsung 950 Pro, 960GB Sandisk Ultra II 3 x 8TB Seagate HDD's | PSU: 750W Seasonic X series, black / orange cablemod cables| Monitors: 3x Asus VX24AH's | AUDIO OUT: Microlab SOLO 8C, Sennheiser HD 650's, Audio engine D1 Amp / DAC | AUDIO IN: Blue Snowball | Keyboard: CM Storm QuickFire TK MX Green | Mouse: Logitech G900 Proteus Spectrum + RSI Extended Mouse Pad | PCPP Linkhttp://nz.pcpartpicker.com/list/hPjFd6
https://linustechtips.com/topic/209219-two-cpu-8-pin-connectors/#findComment-2839356
What motherboard requires two 8-pin CPU cables? No PSU has more than 1 of those cables.
Motherboard: Gigabyte Z97X-UD3H CPU: i5 4690k GPU: Gigabyte GTX 970 4GB PSU: EVGA Supernova G2 750w RAM: Corsair vengeance 8GB @ 1600mhz Case: Fractal Design define R5 CPU-Block: EK-Supremacy Acetal GPU-Block:EK-FC970 GTX WF3 Pump: Alphacool VPP655  Reservoir: EK-XRES 140 D5 HDD: WD Blue 1TB Keyboard: Ducky shine 3 /w mx black
https://linustechtips.com/topic/209219-two-cpu-8-pin-connectors/#findComment-2839358
Cheers!
You should only need the second 8 pin if you're doing some serious overclocking. /I think.
P.s. The EVGA G2 750 w comes with 2 cpu 8 pins, and its only like $100. So, not all of them are amazingly expensive.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/209219-two-cpu-8-pin-connectors/#findComment-2839359
Xpower and One of the ROG boards I believe (don't quote me on that though).
The EVGA G2 750w does.
PSU Tier List | CoC
https://linustechtips.com/topic/209219-two-cpu-8-pin-connectors/#findComment-2839362
I'm getting too old for this shit.
https://linustechtips.com/topic/209219-two-cpu-8-pin-connectors/#findComment-2839372
This isn't for a gaming/enthusiast type board, it's a dual processor supermicro board, pretty sure i need both or bad things will start to happen to my nice xeons
https://linustechtips.com/topic/209219-two-cpu-8-pin-connectors/#findComment-2839378
Almost every high end PSU will come with two of these.
https://linustechtips.com/topic/209219-two-cpu-8-pin-connectors/#findComment-2839397
Is there any way to get around buying a new power supply? Using adapters, custom botch-jobbing a cable in, going all out and soldering a new set of cables in entirely?
https://linustechtips.com/topic/209219-two-cpu-8-pin-connectors/#findComment-2839437
As str_mape said, you don't need to have both plugged in, it's only for very serious overclockers.
https://linustechtips.com/topic/209219-two-cpu-8-pin-connectors/#findComment-2839469
Overclocking isn't even in the frame with this board, it's a server one...
https://linustechtips.com/topic/209219-two-cpu-8-pin-connectors/#findComment-2839477
Adapters exist, like this one here http://www.memoryexpress.com/Products/MX17077
Personally I'd recommend a new PSU though, something that was designed to be used in a scenario such as this.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/209219-two-cpu-8-pin-connectors/#findComment-2839682
That looks ideal, thanks! I couldn't find any anywhere
And as for a new power supply... eh, money.
In the long run i'll probably get a nice redundant setup going, but for now this will have to do
https://linustechtips.com/topic/209219-two-cpu-8-pin-connectors/#findComment-2839786
So you're buying/got a dual socket server grade board but can't afford a power supply?
CPU: AMD Ryzen 7 3700X - CPU Cooler: Deepcool Castle 240EX - Motherboard: MSI B450 GAMING PRO CARBON AC
RAM: 2 x 8GB Corsair Vengeance Pro RBG 3200MHz - GPU: MSI RTX 3080 GAMING X TRIO
https://linustechtips.com/topic/209219-two-cpu-8-pin-connectors/#findComment-2843258
Yep, that's me! It's a budget system, so if i can not buy something and bodge what i already have i will.
There exist PCI-E Power to EPS12V which I'd very much recommend over 4-pin Molex to EPS12V. 4-pin Molex aren't really designed for providing all too much power.
I was thinking that the single 12v cable on molex would be a bit stretched to provide for a whole 8pin eps connector, yeah. I'll get looking for one of those adapters, sounds like a much better plan.
https://linustechtips.com/topic/209219-two-cpu-8-pin-connectors/#findComment-2844905
You don't need to plug in the second 8 pin unless you are running something like a dual processor configuration for which I would highly recommend you buy a good power supply like the EVGA one. If your board has two 8 pins and only has a single processor it is probably just to regulate the voltage going into the processor at very high levels of overclocking, which if you are doing you should only do with expensive power supplies.
https://linustechtips.com/topic/209219-two-cpu-8-pin-connectors/#findComment-2845041
MSI Big Bang XPOWER 2. http://www.newegg.com/Product/Product.aspx?Item=N82E16813130626 It's not uncommon for high end motherboards.
https://linustechtips.com/topic/209219-two-cpu-8-pin-connectors/#findComment-2845068
  • 7 months later...
I plan on using the supermicro board with two x5450s. My power supply is only 450 watts which is enough for both the processors and a gtx 750ti, but i only have one pin EPS power. If you used molex adapters, did they work? Or should i get a splitter like this?$_57.JPG
MAIN RIG: Dell Precision T5500 -CPU: Intel Xeon W5580 (4c,8t@ 3.2ghz,turbo 3.46) -MOTHERBOARD: Dell Precision T5500 OEM -RAM: 16gb ECC DDR3 FBDIMM (Hynix) -GPU: Gigabyte GTX 770  OC WINDFORCE X3 -Case: Dell Precision T5500 OEM -STORAGE: 240gb ADATA Premier SP550 (OS, Programs), 2x 500GB WD Caviar WD5000AAKS (Games, Files) (RAID 0) -PSU: Dell Precision T5500 OEM (875w) -DISPLAY(S): Primary: Acer AL2016w (1680x1050), Left and Right: Gateway FPD1976W (1440x900), Extra displays around the room: 42" Vizio TV (1920x1080) -COOLING: Dell Precision T5500 OEM -KEYBOARD: Logitech G710+ -MOUSE: Logitech G502 Proteus Core -SOUND: Logitech x320 and Razer Electras -OPERATING SYSTEM: Windows 10 Pro x64
LAPTOP: Dell Precision M6500 -CPU: Intel Core i7 920xm (4c,8t@2.0ghz,turbo 3.2ghz) -RAM: 12gb DDR3 -GPU: ATi Firepro M7820 -STORAGE: 240gb ADATA Premier SP550 (OS, Programs), 500GB Seagate STL500LM000 SSHD (Games, Files) -DISPLAY: 1920x1200 17.3” -OPERATING SYSTEM: Windows 10 Pro x64
SECONDARY RIG: -CPU: 2x Intel Xeon x5450 (4c, 4t ea., 8c, 8t @3ghz total) -MOTHERBOARD: Corvalent BDPEX -RAM: 14GB ECC DDR2 (Mix Match of Brands) -GPU: Nvidia Quadro NVS 285 -CASE: No Case (Everything is mounted on the wall in my closet) -STORAGE: 160GB WD Caviar SE WD1600AAJS (OS, Programs, Files) -PSU: 450w BFG -DISPLAY: Samsung UN22D5000 (1920X1080) -COOLING: Dell Precision T5400 Heatsinks and some random fans -KEYBOARD: Logitech G105 -MOUSE: Logitech M215 Wireless Mouse -OPERATING SYSTEM: Windows 7 Professional x64
NAS: -CPU: Intel Pentium e2180 (2c, 2t@2ghz) -MOTHERBOARD: HP Compaq DC5800 OEM -RAM: 2GB DDR2 (Unsure of Brand) -CASE: No Case (Everything is mounted on the wall in my closet) -STORAGE: 500GB HGST (Backup) -PSU: HP Compaq DC5800 OEM (300w) -DISPLAY: Samsung UN22D5000 (1920X1080) -COOLING: Cooler Master Hyper 101a (Zip Tied) and some random fans -OPERATING SYSTEM: FreeNAS 9.10 (Running From USB Flash Drive)
FOLDING RIG: Dell Precision T5400 -CPU: 2x Intel Xeon X5450 (4c, 4t ea., 8c, 8t @3ghz total) -MOTHERBOARD: Dell Precision T5400 OEM -RAM: 32gb ECC DDR2 (Hynix) -GPU: Nvidia Quadro NVS 290 -CASE: Dell Precision T5400 OEM -STORAGE: 250gb WD 250ABYS (OS, Programs, Files) -PSU: Dell Precision T5400 OEM -DISPLAY: Dell 1707FP (1280x1024) -COOLING: Dell Precision T5400 OEM -OPERATING SYSTEM: Windows 10 Pro x64
PHONE: iPhone 7 32GB Matte Black (Sprint)
https://linustechtips.com/topic/209219-two-cpu-8-pin-connectors/#findComment-4844878
Oh it's a server board. Yes you'll need that 2nd 8-pin plugged in. There's plenty of molex-to-EPS power adapters out there, and chances are you won't be overclocking those Xeons so you'll be fine using one of those. Preferably if you can find one that takes two molex and turns it into an 8-pin EPS.
"Rawr XD"
https://linustechtips.com/topic/209219-two-cpu-8-pin-connectors/#findComment-4864395
