I dye fans if anything, not paint.
https://linustechtips.com/topic/207307-painting-case-fans/#findComment-2812732
You could get something from bequiet instead, it already has black fans + black heatsink, it will perform very very similar.
Painting fans is difficult to get right, and so is dying from what I've seen.
https://linustechtips.com/topic/207307-painting-case-fans/#findComment-2812799
I think you can remove the fan blades. Just get spray paint for plastics and give 'em a few light coats until desired.
If you do this, you break the oil seal, once this is broken, the fans won't last long.
https://linustechtips.com/topic/207307-painting-case-fans/#findComment-2812835
You can get the Redux or the industrialPPC fans.
https://linustechtips.com/topic/207307-painting-case-fans/#findComment-2812841
What cooler specifically from bequiet?
-From the desk of Moose-
https://linustechtips.com/topic/207307-painting-case-fans/#findComment-2812857
http://www.ncixus.com/products/?sku=93614&vpn=BK018&manufacture=be%20quiet%21&promoid=1011
you could get that, it looks similar in size to the one you were eyeballing :P
https://linustechtips.com/topic/207307-painting-case-fans/#findComment-2813047
Thanks! This is going to look great in a Define R4 :)
I have an R4 myself, sub to my build log if you want it's in my signature :P
https://linustechtips.com/topic/207307-painting-case-fans/#findComment-2813365
