So I got my new ECS board today and it has the same issue as the ASrock board!
Doesn't want to boot with all 4 sticks!!
WTH!
On my AMD build it works perfectly fine but on the Intel build it doesn't....
All opinions welcome...
Thanks.
Intel Core I7 7820X | Asus Rampage VI | Gigabyte RX 580 XTR | 32GB Crucial Ballistix | NZXT Kraken X62
ADATA XPG 256GB PCIe| Cosmos C700P CM | Lepa MaxPlatinum 1050W
https://linustechtips.com/topic/207004-another-memory-issue-fml/
WTH!
Thanks.
Use Memtest86+ and validate every stick of ram.
Are they matching Set / Pairs in each channel?
Main Machine:  16 inch MacBook Pro (2021), Apple M1 Pro (10 CPU, 16 GPU Core), 512GB SDD, 16GB RAM
Gaming Machine:  Acer Nitro 5, Core i7 10750H, RTX 3060 (L) 6GB, 1TB SSD (Boot), 2TB SSD (Storage), 32GB DDR4 RAM
Other Tech: iPhone 15 Pro Max, Series 6 Apple Watch (LTE), AirPods Max, PS4, Nintendo Switch, PS3, Xbox 360
Network Gear:  TP Link Gigabit 24 Port Switch, TP-Link Deco M4 Mesh Wi-Fi, M1 MacMini File & Media Server with 8TB of RAID 1 Storage
https://linustechtips.com/topic/207004-another-memory-issue-fml/#findComment-2808660
ECS is one of the brands i don't trust. Honestly, it could be the RAM or the board. I have an Asrock board that works fine with mismatched DIMMs on Intel.
[TRUENO] i7 4770k (~4.4Ghz, 1.28v) || Thermalright Macho 120 || Asus Z87 Gryphon || 2x8Gb Mushkin Blackline|| Reference NVIDIA GTX770 || Corsair Neutron GTX 480GB || 2x3TB WD HDD || Corsair 350D || Corsair RM750
https://linustechtips.com/topic/207004-another-memory-issue-fml/#findComment-2808674
Make sure all of the DIMMs are matching. Make sure the board will actually use all four slots at once.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/207004-another-memory-issue-fml/#findComment-2808684
Check the RAM compatibility page on the motherboard's website. Also, this may sound stupid, but try and reseat the CPU.
https://linustechtips.com/topic/207004-another-memory-issue-fml/#findComment-2808692
ECS is pretty bad
https://linustechtips.com/topic/207004-another-memory-issue-fml/#findComment-2808745
ECS is pretty bad
I didn't want to say that too loudly, but yes, I agree. Asrock isn't that amazing either.
https://linustechtips.com/topic/207004-another-memory-issue-fml/#findComment-2808767
ASRock has been really good for me, but ive only had one board. Z77 Extreme6
Ryzen 7 5800X3D , Arctic Liquid Freezer  III , Gigabyte X570 Aorus Elite , Corsair Vengeance 32GB , Gigabyte RTX 5070Ti ,  WD SN850 / MP44L
Corsair RM 850x, LIAN LI Lancool 207
https://linustechtips.com/topic/207004-another-memory-issue-fml/#findComment-2808779
ECS is pretty bad
To confirm with everyone 2 of the memory sticks are bad.
https://linustechtips.com/topic/207004-another-memory-issue-fml/#findComment-2808970
The board works flawless ( Knock on wood )
But it was my memory
https://linustechtips.com/topic/207004-another-memory-issue-fml/#findComment-2808974
-_- That might be what your problem is. ;)
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/207004-another-memory-issue-fml/#findComment-2808978
Sorry your RAM is fuxxored. Check and see if it has warranty, most RAM has lifetime.
https://linustechtips.com/topic/207004-another-memory-issue-fml/#findComment-2808981
When I put the other 2 sticks in the computer wont boot.
But when I put the 2 working sticks it works fine.
I have the Avexir memory so the only problem with them is that they don't have an office in the US.
So they would have to ship it from Taiwan.
Not sure how long that would take
https://linustechtips.com/topic/207004-another-memory-issue-fml/#findComment-2809011
Lucky :) Memory is cheaper to replace than a motherboard ;)
https://linustechtips.com/topic/207004-another-memory-issue-fml/#findComment-2809088
His board is cheaper than good 8GB memory lol :D
https://linustechtips.com/topic/207004-another-memory-issue-fml/#findComment-2809105
True...
https://linustechtips.com/topic/207004-another-memory-issue-fml/#findComment-2809107
Here's the thing though...
If it was my memory from the start I now have 2 working motherboards.
The ASrock Extreme and the ECS Black Extreme
So I might just buy new memory
https://linustechtips.com/topic/207004-another-memory-issue-fml/#findComment-2809269
You could return the newer one, or you could toss it on /r/hardwareswap
https://linustechtips.com/topic/207004-another-memory-issue-fml/#findComment-2809403
