So I'm going to do a build for a friend, and I really want to water cool it, BUT I have very little experience with picking out parts for one, from watching a lot of videos on it I have a relatively good understanding on how to do a good loop and that I need a reservoir, pump and blocks (tubing and fittings). I only want to spend $150 on the loop but I can go up to $200, also other than a heat gun and saw/something to cut, what tools do I need? BTW tubing must be acrylic. Sorry, I really want to make this look good. Also Linus should really do a water cooling guide.
https://linustechtips.com/topic/204193-first-time-water-cooling/
Sorry but if you want to make a custom watercooling loop you will need to spend at least $500, even more if you want hard tubing.
I suggest you get a basic AiO liquid cooler from Corsair or NZXT which cost less than $150
https://linustechtips.com/topic/204193-first-time-water-cooling/#findComment-2772866
Good luck trying to make a loop for that cheap. You can't even get a pump/res combo for less than 150. And then add on fittings, blocks, and tubing. That can run you as high as over one grand.
https://linustechtips.com/topic/204193-first-time-water-cooling/#findComment-2772872
This is cut and paste from another thread asking pretty much the same question. I couldn't be bothered retyping it.
Lets use frozen Cup's site
EK CPU block - EK supremacy elite = 127 USD
EK VGA Block - EK 780dcu2 = $125 USD
EK D5 Pump Vario = $115-120 USD
EK Cool Stream 240 Rad = $60 USD
EK Cool Stream 360 Rad = $76 USD
EK Tube Res = $50 - 130
Primochill PETG 4 x 36 inch clear 1/2 od tube = $11 usd
Primochill compatible fittings for the tube = $7 USD ea.
Cheapest will be around the $660 USD Mark
Most expensive options, around the $830 USD Mark.
Please note excludes shipping
MOBO: ASUS X79 Pro CPU: i7 3820 Ram: Corsair Vengence 32Gb 2133mhz (8x4) GPU: 2 x Sapphire R9 290 in X-fire PSU: Seasonic G series 750w Drives: 1 x 750 gig WD black, 3x WD Black 1TB, 1 x Segate Barrcuda 1 TB, 1 x Toshiba 2TB, Intel 520 240gig SSD Case: Enthoo Primo w/ Green and Blue LED lighting.
https://linustechtips.com/topic/204193-first-time-water-cooling/#findComment-2773822
Cooler Master Seidon 240M for $60.  You CANNOT beat this deal.  Amazing performance for very little money.
Liquid Cool for CPU for $60  Then Get a G10 + 120mm AIO + Heatsinks for the GPU totaling around $120.
BAM!  You just water cooled your system for less than $200 and temps never go above 50C with fans at 60% speed.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/204193-first-time-water-cooling/#findComment-2773988
You could always go for the new Swiftech H220x, which gives you the ability to customize and expand at a gradual rate while still giving solid performance and that custom watercooling feel. Another option to consider. I myself use the H105 and it looks the bomb, with temp barely scratching 60 at a 4.8GHz, 1.3V overclock. Can't recommend it enough!
i5 4690K | Asus Ranger VII | 8GB HyperX Fury | Asus GTX 780 | NZXT H440 | Samsung 850 Evo | Seagate Barracuda | Corsair RM 750W | Corsair H105
E3-1246 v3 | Asus Gryphon Z97 | 8GB HyperX Fury | MSI GTX 970 | Enthoo Evolv mATX | Samsung 840 Evo | WD Red | EVGA SuperNova GS 650W | NZXT Kracken x41
https://linustechtips.com/topic/204193-first-time-water-cooling/#findComment-2774286
