Help picking case £90~
Hinesd
I'm looking for a case with windowed side panel, dust filters and support for water cooling since I plant to water cool in the future. I'll be willing to spend up to £100 if the case is perfect. I have looked around but haven't found the perfect one. I like the functionality and air cooling potential CM 690 III and the looks are ok however I really prefer the looks of NZXT H440W however I can't decide since I am not sure about its cooling potential, it looks quite restrictive. Basically these are the case choices I am stuck between- Phanteks entho pro (white), CM 690 III, Define R4 Windowed, NZXT H440W. Thanks in advance.
750D if you can stretch to £120.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
http://uk.pcpartpicker.com/part/phanteks-case-phes614pwt
Phanteks Enthoo Pro
Amazing reviews all round! They're entering a market so they have to be cheap :>
I do agree with that case.  Especially for water cooling that one is the clear winner.
The H440 isn't to bad for water cooling either. But lacks a few amazing features that the Enthoo Pro does got. Especially reservoir mounting.
The Define R4 is not that easy to go water with as far as I am aware.
The CM 690 is oké as far as I heard, but I never looked to much at it, so can't really say.
NZXT Phantom windowed, Asus Z77 Sabertooth, Intel 2600K, Noctua NH-D14, EVGA 780 Classified, Crucial Ballistic Tactical, Crucial M4 128GB + Samsung 850 EVO, Corsair RM850, Creative X-Fi Fatal1ty Peripherals: Sennheiser HD598, FinalMouse Classic, SteelSeries Qck Heavy, Ducky Shine Zero (MX Brown), AOC G2460PF & Qnix QX2710
Build Log: Phantom - Antique Noctua
Ever heard of the Arc XL?
