Temps On Idle | Are They Normal
I currently have a i7 4770K running at 3.5GHz (Stock clock for now just to save the life span of the CPU until I start doing more gaming and animations again)
Its being cooled by a Corsair H100i
But these temps look to high for running on idle
EDIT: I re-apply thermal paste about every 3-4 months.
EDIT 2: These are the temps when my fans are cranked up to max RPM's
https://linustechtips.com/topic/201766-temps-on-idle-are-they-normal/
I have a 4770k at 4.4ghz on air with a NH-D14 and I get lower temps than you on idle, you could try better TP or reseat the cooler, but those are fine either way.
ZEUS
CPUi7 4770K - 4.4Ghz CoolerNoctua NH-D14 MB: Maximus VI Hero RAM4 x 4GB Vengeance Pro DDR3 2133Mhz GPUWindforce 780ti Case: Corsair C70 Storage: 3 x 128GB 840 Pro SSD in RAID 0 , 2 x 1TB Barracuda PSU860W AX860i Displays: Asus VG248QE 144Hz , Asus VE247H 60Hz KeyboardRazer Blackwidow 2013 MouseRazer Deathadder SoundSennheiser HD 558 Mic: Blue Snowball
"If I'm not quoted I probably won't reply back to you."
Idle temps don't really matter. It's load temps that are much more important.
What are your load temps?
I actually couldn't underclock my 5 year old GPU to make it as slow as a next-gen console.
#pcmasterraceproblems
~Slick
What's more important are your temperatures under load.
lol the hottest I ever had that thing running is 100c I played crysis 3 maxed out :P almost fried my cpu >.<
Those temps are extremely, extremely, extremely, high with the cooler you have and at stock clock speeds. Re-apply your thermal paste PROPERLY and install the cooler PROPERLY before your CPU dies a horrible death.
~Slick
like I said above I re apply thermal paste every 3-4 months.
EDIT: I will probably re apply it this weekend.
These are the temps when I crank the fans up to full throttle on idle
wow, that kinda hot for a h100i under no load. my cpu under no load with the stock cooler is at (no joke) 24*, my room is like 22*
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
It's also not necessary to reapply thermal paste every few months.
~Slick
Your CPU or cooler might be defective, or you're applying your thermal paste incorrectly.
It might be your room temperature also, but that would mean your house is a boiler with those temps.
#SAMSUNG  "provided us 4 1tb ssds so we could run the whole site off solid state." - LinusTech
#GALAXY
#ATIV
