Get a laptop
CPU: AMD FX-8120 | CPU Cooler: Thermaltake Contac 30 | Motherboard: GIGABYTE GA-990FXA-UD3 | Memory: Kingston 16GB (4 x 4GB) DDR3-1333 | Storage: WD 1TB | GPU: Gigabyte Radeon HD 7870 | Case: Thermaltake Chaser MK-I | PSU: Thermaltake Black Widow 850W
https://linustechtips.com/topic/197121-ideas-for-car-pc/#findComment-2673418
Hi just wondering if any of you people on the forum have any ideas for a car pc?
What sort of hardware? (keeping wattage low)
intel NUC
CPU: Intel Core i7 4790k CPU Cooler: Corsair H100i Chassis/Case: Fractal Design Arc Midi R2  Motherboard: Asus Z87-Deluxe RAM:  Team Vulcan 2x4Gb(2133Mhz)  Video Card: Asus 7970 Direct CU II Custom Rom (150% Power, 1100 core 6Ghz Memory)  Power Supply: Fractal Integra R2 750 Watt  Keyboard: Cooler Master Quick Fire Rapid (MX Blue Switches)  MouseCorsair M90 Storage: SX900 128Gb, Seagate 1TB 7200RPM, WD Green 1TB 7200RPM   MY OLD BUILDLOG
The Fastest 8350 @5.33Ghz with a score of 9.16pts in Cinebench 11.5
https://linustechtips.com/topic/197121-ideas-for-car-pc/#findComment-2673420
A car pc? You mean a pc to use in a a car? A pc that looks like a car? A OC the size of a car? Explain yourself...
As in a small desktop to put in boot of car to be used as a sort of media pc
also Skoda Fabia Estate
(plan to put 2 of these : http://www.ebay.co.uk/itm/7-inch-LCD-Car-monitor-computer-HD-digital-VGA-AV-Support-as-Computer-Screen-/321308277188 on back seats )
Computer Programming Nerd Guy + Computer Support @ Red Tree IT
https://linustechtips.com/topic/197121-ideas-for-car-pc/#findComment-2673447
You mean a PC that can be used in a car? :S You could try making a briefcase PC?
This guy did, it's a bit old but damn it's a project i'd like to do one day.
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/197121-ideas-for-car-pc/#findComment-2673452
It's possible, but you might want to get a good inverter (something around a 600W inverter) if you want to build a standard desktop-ish computer....
Otherwise get a NUC, or a Zotac, or a Brix...
https://linustechtips.com/topic/197121-ideas-for-car-pc/#findComment-2673459
"Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves." - Albert Einstein
The same applies to computers. Cars are meant for driving, not for computer usage whatsoever.
Compatible with Windows 95
https://linustechtips.com/topic/197121-ideas-for-car-pc/#findComment-2673465
Not for use in the front... for use in the back e.g. for when I drive to london which I do quite alot having a movie collection will keep my younger sister quiet!
Also I fancied doing it as an entertaining project!
https://linustechtips.com/topic/197121-ideas-for-car-pc/#findComment-2673480
'tis a good idea, my friend, but why not just use DVD players like everyone else?
https://linustechtips.com/topic/197121-ideas-for-car-pc/#findComment-2673487
because of the size constrains its either a nuc or  (which i recommend) ECS's  liva pc  comes with nand ram and a dual core baytrail CPU at a great price
If your grave doesn't say "rest in peace" on it You are automatically drafted into the skeleton war.
https://linustechtips.com/topic/197121-ideas-for-car-pc/#findComment-2673499
go on ebay get a cheap portable dvd player that has an hdmi input (many do) then get a back of seat mount for those guys which again are pretty common. After that get a rabserry pi. I would reccomend getting a case for it aswell so you can make it nice and tidy. Also get a hdmi cable micro sd card and a wireless keyboard mouse combo thingy.
then install xmbc on the pi and use a flash drive to load movies on it.
That way you can use dvds and movies from your pc. It will probally cost you anywhere from 50-75 bucks if you do it right.
https://linustechtips.com/topic/197121-ideas-for-car-pc/#findComment-2673530
Nice attempt at being pseudo-intellectual. A friend of mine works as a security guard, and sits in his small van, and doing foot patrols at intervals. He has a laptop in it so he can watch movies / game in-between his patrols.
https://linustechtips.com/topic/197121-ideas-for-car-pc/#findComment-2673597
Have you considered a Raspberry Pi? OC it to 1GHz, and it will run a XBMC distro without any problems.
already have considered raspberry Pi - however plan is to have dual displays running - so going to have to be windows based + my plan is to have my itunes library with it anyway - probably thinking a AMD APU based system with a 1tb hard disk
https://linustechtips.com/topic/197121-ideas-for-car-pc/#findComment-2673674
Why thankyou
(I could not be bothered to find a suitable quote to match the situation, I have let you down)
Those+are+some+good+maymays+friend+_6f67
https://linustechtips.com/topic/197121-ideas-for-car-pc/#findComment-2673701
