Whos got the budget......
Liquid Cool Cpu, Gpu, hard drive.
Get a high watt psu were the fan doesn't kick in unless gaming.
get a "Silent" pump for the loop as well.
anyone want to take the challenge on LoL
No Fans needed...
https://linustechtips.com/topic/195936-fan-less-pc/
No Fans needed...
dude what the fk are you trying to say
Error: 410
https://linustechtips.com/topic/195936-fan-less-pc/#findComment-2657600
How about the completely silent one by Swiftech
and you need fans on the radiators unless you get like super thick huge rads everywhere
FANBOY OF: PowerColor, be quiet!, Transcend, G.Skill, Phanteks
FORMERLY FANBOY OF: A-Data, Corsair, Nvidia
DEVELOPING FANBOY OF: AMD (GPUS), Intel (CPUs), ASRock
https://linustechtips.com/topic/195936-fan-less-pc/#findComment-2657601
Get a tablet or ULV Ultrabook
A PC where there's fans, but they don't turn on till heavy load. So when just browsing web, doing MS office stuff or watching movies it's completely silent
No Fans needed...
Low power CPU like G3258 + one of those big fanless CPU coolers
Asus STRIX graphics card
SSD
AX series PSU
"Rawr XD"
https://linustechtips.com/topic/195936-fan-less-pc/#findComment-2657605
then I guess we're not looking for liquid cooled ones or ones with pumps in it.
Error: 410
https://linustechtips.com/topic/195936-fan-less-pc/#findComment-2657620
I was thinking further....lol, No Fans
theirs blocks for hdds :D
https://linustechtips.com/topic/195936-fan-less-pc/#findComment-2657624
That's not possible. Even with liquid cooling you need airflow through the radiators even at idle since they do not work passively. The temps will continue to rise until they settle at the passive cooling capacity which will be over 50C for sure.
https://linustechtips.com/topic/195936-fan-less-pc/#findComment-2657636
hmm thats a good point,
Blocks make noise. I've heard blocks that are noisier then Noctua S12's or Be Quiet Silent Wings 2's
damn
https://linustechtips.com/topic/195936-fan-less-pc/#findComment-2657644
The best way to silently cool a PC is to have the radiator and fans in a separate room with tubing going to the PC. Anything that is completely passive will be extremely low power like a netbook or a raspberry pi
https://linustechtips.com/topic/195936-fan-less-pc/#findComment-2657656
thats what linus is doing now :D will see how it works out
https://linustechtips.com/topic/195936-fan-less-pc/#findComment-2657813
My brother has a Asus assembled computer. With a 5600 APU and the only cooling on it is the CPU heatsink, and the PSU which is 280watt or so cooling itself. That is all! Two weeks back, he added a 120mm or 80mm though. Temps before: around 40. He says some software efficiently said it was 80*c.
To love is to risk not being loved in return. To hope is to risk pain. To try is to risk failure, but risk must be taken because the greatest hazard in life is to risk nothing.
https://linustechtips.com/topic/195936-fan-less-pc/#findComment-2657854
