Monitor for Workstation
jedylan
Building a gtx780 based pc that I will use for video editing, photo editing, music mixing and gaming.
I am currently looking at monitors and cant choose between the Asus PB278Q and PA248Q. I would buy two of them (If I take the PB278Q I will have to wait a few weeks before buying the second and I would need to buy a calibrator)
Is Dual 27" too much?
Is the quality of the PA much better?
The PB278Q is getting an update soon, i'd wait for the PB278QR to come out where you live.
the pa is factory calibrated, but still uses the same panel, so if you adjust the colors yourself on the pb, there wont be any picture difference
also dual 27" is not too much. id go as far as to say you cant have enough monitor space.
So Id advise you to go with the two 27" monitors, but as @Mooshi said, wait for the updated PB278QR
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
have you considered an ultra wide screen? (21:9)
CPU: R5 1600 @ 4.2 GHz; GPU: Asus STRIX & Gigabyte g1 GTX 1070 SLI; RAM: 16 GB Corsair vengeance 3200 MHz ; Mobo: Asrock Taichi x470; SSD: 512 gb Samsung 950 Pro Storage: 5x Seagate 2TB drives; 1x 2TB WD PurplePSU: 700 Watt Huntkey; Peripherals: Acer S277HK 4K Monitor; Logitech G502 gaming mouse; Corsair K95 Mechanical keyboard; 5.1 Logitech x530 sound system
 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01100100 01101111 01100101 01110011 01101110 00100111 01110100 00100000 01101101 01100001 01101011 01100101 00100000 01111001 01101111 01110101 00100000 01110000 01110010 01101111 00101110
You might find you like working with a 3440x1440 monitor (ultrawide) more than the standard 2560x1440: I used to use 2 1920x1080p monitors before I got the 34LGUM95, and i am glad I made the switch. Though one of its biggest perks is that it uses Thunderbolt, and I'm a mac user which means its pretty effortless (i've gotten it to work on windows 7 but you need to install drivers where as mac is just plug and play).
That being said, I wouldn't go back to 1920x1080 for productivity, and I think 2 of these 34 inch monitors are too much, but I'm not sure how I feel about 2 27 inch monitors, but I suppose I wish I had something like a 32'' 4k display instead of 34'' 3.5k display, but this comes very close for a fraction of the price, and its much easier on my laptop to run.
I have a 2019 macbook pro with 64gb of ram and my gaming pc has been in the closet since 2018
Yes I have but I am still not sure about the aspect ratio. It is same height as 27" same price as dual 27" but less screen real estate. I am looking at every possibility
I love it personally, but I guess it might not be everyone's thing, the thing with multi monitor editing is that the bezels would be in the middle of you design if stretching it to see more content, I suggest watching a few reviews etc. and making a decision. from me personally though, even from a multitasking, watching movies or gaming perspective.. I love my monitor.
