Difference Between Tri-X and Vapor-X 290X?
Solved by WereCat,
Vapor X is using Vapor chambers for cooling. It should be more effective cooling than using normal heat pipes.
http://www.sapphiretech.com/vaporx/VaporX_paper.html
Friend of mine got R9 280x VaporX and it is dead silent on idle and quite silent in load.
Featured Topics
GoStormPlays ·
Posted in General Discussion0 -
2
jordan_wills ·
5
xJDL ·
Posted in Troubleshooting1 -
Marie Rose ·
Posted in Power Supplies9 -
8
7
8
17
