Posted July 29, 2014 Hello, im in need of a unlocked phone that I can use both in Mexico and usa. Currently i have an LG Motion with MetroPCS, it works just right for me. Only thing i do not like about it is battery life. It last almost a day when i do not use it for other thing than occasional messaging. I do not need an ultra fancy and expensive phone. I googled and found some that can have dual SIM cards, that might work. But most of the time I will not switch between the countries constantly. In USA I would be using MetroPCS network... and in Mexico I would use either Movistar or Telcel(mostly movistar). I have seen some Huwaei phones under $100, are these good? I know nothing about phones and if there are compability issues with carriers and what not... So...what phones should i look into? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 29, 2014 Hello, im in need of a unlocked phone that I can use both in Mexico and usa. Currently i have an LG Motion with MetroPCS, it works just right for me. Only thing i do not like about it is battery life. It last almost a day when i do not use it for other thing than occasional messaging. I do not need an ultra fancy and expensive phone. I googled and found some that can have dual SIM cards, that might work. But most of the time I will not switch between the countries constantly. In USA I would be using MetroPCS network... and in Mexico I would use either Movistar or Telcel(mostly movistar). I have seen some Huwaei phones under $100, are these good? I know nothing about phones and if there are compability issues with carriers and what not... So...what phones should i look into? Moto E/G. MetroPCS requires 1700 and 2100 MHz 3G frequency bands "Rawr XD" Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 29, 2014 Moto G @Aniallation why quote OP? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 29, 2014 there are cheap nokia phones with dual sim check them out If your grave doesn't say "rest in peace" on it You are automatically drafted into the skeleton war. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 29, 2014 @Aniallation why quote OP? its a habit "Rawr XD" Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 29, 2014 And they usually don't follow their topic What are you saying man? "Rawr XD" Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 29, 2014 Movistar requires 850 MHz and 1900 MHz though it supports them too Pretty much any UTMS (GSM 3G capable) phone in NA nowadays will support 850/1900. It's finding the phones that support AWS 3G (1700/2100) that's a pain in the ass. I use Wind up here in Canada which also requires your phone support AWS on 3G, but unlike MetroPCS or un-refarmed T-Mobile, they don't even have a 2G network to fall back onto, so you're really limited as to what phone you can use "Rawr XD" Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 29, 2014 And they usually don't follow their topic DEcobra11, on 29 Jul 2014 - 11:57 PM, said: And they usually don't follow their topic DEcobra11, on 29 Jul 2014 - 11:57 PM, said: And they usually don't follow their topic DEcobra11, on 29 Jul 2014 - 11:57 PM, said: And they usually don't follow their topic DEcobra11, on 29 Jul 2014 - 11:57 PM, said: And they usually don't follow their topic DEcobra11, on 29 Jul 2014 - 11:57 PM, said: And they usually don't follow their topic DEcobra11, on 29 Jul 2014 - 11:57 PM, said: And they usually don't follow their topic DEcobra11, on 29 Jul 2014 - 11:57 PM, said: And they usually don't follow their topic DEcobra11, on 29 Jul 2014 - 11:57 PM, said: And they usually don't follow their topic DEcobra11, on 29 Jul 2014 - 11:57 PM, said: And they usually don't follow their topic DEcobra11, on 29 Jul 2014 - 11:57 PM, said: And they usually don't follow their topic Quoteception. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 30, 2014 Author Thanks for your replies! Moto G and E looks nice. Most likely will end with some of these. I did not research a lot, but seems like dual sim Nokia phones are either Windows phones or some other OS... When ordering the moto G from Motorola page it has the option of "Moto G 4G LTE -- US GSM", that is the one I would need, right? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
