I am sure this has been asked before but every system is different and all the tips i found didn't help.
So as the title suggests, I  get low fps with my gtx 780 ghz edition. It's not OCed, no is the CPU right now, the driver is up to date. I recently switched to Windows 8.1 but I hardly think that's the problem (?).
Interestingly the GPU doesn't even go to maximum clock speed. GPU is in the first PCIe slot. The CPU load is only 8%.
Any ideas?
-vT
5.1GHz 4770k
My Specs
Intel i7-4770K @ 4.7GHz | Corsair H105 w/ SP120 | Asus Gene VI | 32GB Corsair Vengeance LP | 2x GTX 780Ti| Corsair 750D | OCZ Agility 3 | Samsung 840/850 | Sandisk SSD | 3TB WD RED | Seagate Barracuda 2TB | Corsair RM850 | ASUS PB278Q | SyncMaster 2370HD | SyncMaster P2450
https://linustechtips.com/topic/187550-low-fps-780/
What type of FPS do you get? Could you give a specific game? 8% CPU sounds a bit low to me, even in single player... Maybe I'm wrong but the CPU usage doesn't sound right...
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/187550-low-fps-780/#findComment-2523941
I remember on my old laptop - which had a seperate, dedicated gpu - at one time the gpu couldn't be detected and i got low fps on games because it was running on integrated graphics processing.
Did you plug your monitor into your graphics card? Sometimes I accidentally plug the monitor into the motherboard when making changes.
https://linustechtips.com/topic/187550-low-fps-780/#findComment-2523950
Is your integrated graphics turned off?
https://linustechtips.com/topic/187550-low-fps-780/#findComment-2523977
Sounds like a GPU beching run to me, though let's wait for the OP's answer.
My rig: CPU: Intel core i5 4670K MoBo: MSI Z87-G45 Gaming RAM: Kingston HyperX Beast 2x4GB 1600mhz CL9 GPU: EVGA GTX780 SC ACX SSD: ADATA Premier Pro SP900 256GBHDD: Western Digital RED 2TB PSU: FSP Aurum CM 750W Case: Cooler Master HAF XM OS: Windows 8 Pro
My Build log, the Snowbird (heavy WIP): http://linustechtips.com/main/topic/188011-snowbird-by-lachy/?hl=snowbird
https://linustechtips.com/topic/187550-low-fps-780/#findComment-2524023
That sounds more probable.
https://linustechtips.com/topic/187550-low-fps-780/#findComment-2524044
Bioshock Infinite 2-141fps, avg 42. (ultra preset benchmark)
Tomb Raider 24-38, avg 32 (ultimate preset brenchmark)
CS:S 28-49 fps, avg 38
GPU ramps up to 1175MHz , 1162mVwhen I play the newer games btw.
Maybe I spoke too soon. Looks like it is just CS:S then. :( My most played game -.-
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/187550-low-fps-780/#findComment-2524167
meh. Maybe set up a VM instead? never done that before though, and i don't know how much of an impact thats gonna have on games.
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/187550-low-fps-780/#findComment-2531582
try using FRAPS to bench your normal FPS.
www.fraps.com
Try the beta driver, it may have a work around to your described problem.  When you install make sure to due a custom install so you can do a clean installation.  If this doesn't work try the mfg driver's, same steps for a clean install.  Finally one last thing, check the bios and disable Intel HD graphics, a long shot but it might help.
"We will never make a 32-bit operating system." -- Bill Gates, 1989
https://linustechtips.com/topic/187550-low-fps-780/#findComment-2531818
using 340.43 beta driver and fraps :P
still getting only 40ish fps in CS:S  This is really driving me nuts. Setting the hl2.exe to compatibility mode didn't do anything eitehr.
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/187550-low-fps-780/#findComment-2532109
Do you have Energy Saving Mode in the ASUS Ai Suite activated?
I remember one time I had the same "problem" and after I turned EPU setting from Power Saving to Performance Mode, the PC was a machine again :)
I'll check that. brb.
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/187550-low-fps-780/#findComment-2535700
no energy saving mode :/
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/187550-low-fps-780/#findComment-2545072
You tried to reconect your gpu? Since with that gpu you should get more than 100 fps in bioshock infinite...
What do you mean? Simply take it out, put it back in? :D Sounds a bit too simple ^^
I got a 770, Win8.1 and I get over a lot more FPS in CS:GO than that.... What's your CPU? RAM?
Intel i7-4770K, 32Gb Corsair Vengeance
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/187550-low-fps-780/#findComment-2545368
Try,dosen't cost anything...Back in days i had similar problem with asus n6200 gamer (badass videocard for its times) and i found out that psu cable was not totally in..
https://linustechtips.com/topic/187550-low-fps-780/#findComment-2545554
Right okay so there isn't  a bottle neck.
did you stick your monitor into your motherboard instead of your video card?
Check this, because if you've plugged it in to the motherboard your CPU is running the display, check this. Also power cables to the GPU and PSU, make sure it's plugged properly into the mobo. ALSO no one has asked yet, are you running 3 monitors and using all 3 to game? Or is it just one? Because if it's 3 with a high res that might be way, if it's not then I'm fresh out of ideas.
https://linustechtips.com/topic/187550-low-fps-780/#findComment-2545578
:D yes of course
check. no change :(
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/187550-low-fps-780/#findComment-2545797
...or maybe even running 4k res?
https://linustechtips.com/topic/187550-low-fps-780/#findComment-2545805
