A big pet peeve of mine is when Bla bla blabla bla bla bla bla blaa bla bla bla bla bla blala blabla blala blabla blablabla bla bla bla bla bla
bla
If your grave doesn't say "rest in peace" on it You are automatically drafted into the skeleton war.
https://linustechtips.com/topic/187237-bla-not-bla/
Now this post needs not to exist.
If you had a problem with the other two, you didn't need to make another topic about it. Just report it to a moderator. All you are doing with this is stirring up trouble.
https://linustechtips.com/topic/187237-bla-not-bla/#findComment-2519355
UN. NEC. ESS. AR. Y.
https://linustechtips.com/topic/187237-bla-not-bla/#findComment-2519369
I can relate to Bla bla bla as well.
i5 4670k, GTX 970, 12GB 1600, 120GB SSD, 240GB SDD, 1TB HDD, CM Storm Quickfire TK, G502, VG248QE, ATH M40x, Fractal R4
i5 4278U, Intel Iris Graphics, 8GB 1600, 128GB SSD, 2560x1600 IPS display, Mid-2014 Model
All the parts are here, just need to get customized cords to connect the motherboard to the front panel.
https://linustechtips.com/topic/187237-bla-not-bla/#findComment-2519463
bla
Dubs are better than subs
https://linustechtips.com/topic/187237-bla-not-bla/#findComment-2519477
@qwertywarrior , the reason why I made the post about NVIDIA and AMD being pronounced incorrectly and is reasonable. I'm sure a couple of people learned about NVIDIA and AMD. I was saying NVIDIA incorrectly for 2 years already, until I looked into their website and noticed how it says NVIDIA., not nVidia. I look into an old B&H catalog to find that the GTX 460 is from nVidia, with the PNY logo above it. I researched a little, and I realized that a large number of people are still saying nVidia. This also applies to AMD.
This thread is a rude mock of my post. Bla is indeed the same as bla, because there is no copyright on it, which means that "Bla" is used on the beginning of a sentence, while "bla" is used in the other parts of a sentence. Therefore, "bla" is indeed "Bla".
https://linustechtips.com/topic/187237-bla-not-bla/#findComment-2519511
@qwertywarrior , the reason why I made the post about Cheeze and Crackers being pronounced incorrectly and is reasonable. I'm sure a couple of people learned about Cheeze and Crackers. I was saying Cheeze incorrectly for 2 years already, until I looked into their website and noticed how it says Cheeze., not Cheese. I look into an old moose catalog to find that the Chedar  is from Cheese, with the farmer's market logo above it. I researched a little, and I realized that a large number of people are still saying nVidia. This also applies to AMD.
https://linustechtips.com/topic/187237-bla-not-bla/#findComment-2519528
Guest
