1st time build need review
I'd probably spend more money on a motherboard that has built in wireless AC instead of a wireless N card.
You can likely get away with 8gb of RAM, or a cheaper set of 16gb.
If you don't upgrade often an i7 might make more sense, but for todays games you can get away with an i5.
I'd go with at least a 250gb SSD, judging your budget I'd bump it up to a 500gb at least.
You don't need a 850w power supply.
Any particular reason you went with that monitor?
Featured Topics
MacBookBoy96 ·
Posted in Console Gaming1 -
1
2
ShadowSweaty ·
Posted in Troubleshooting6 -
s1eroo ·
Posted in Graphics Cards3 -
CosmicEmotion ·
Posted in Windows8 -
ki8aras ·
Posted in Troubleshooting2 -
Timiii ·
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
