Ni hao everyone!
So i want to start a little project later this year involving (ofc) watercooling.
I plan on using:
I5 4460
Msi gtx760 ITX version
And i want both of these being cooled by a single thinn 120mm rad (alphacool nexus st30) with a pull fan (new noctua industrials so i can turn em up whe necessary).
Do you think thats possible?
My aim is:
A quiet rig with a little better temps than air but mainly just having a small water cooled rig lol.
I think it should be possible considering that even the single rad on the 295x2 can (kinda) handle its load.
Please post you opinions etc! :)
Thanks and bye! :)
PS: i want to use a very small case so i cant get any more rad space!
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/180626-extreme-close-water-cooling/
@Coombzy @Rorgash @Manny Calavera @Bagmup
Yeah i know its a waste but the only question is if its possible at all and if it would be better or the same as water cooling
My first thought was to use a low profile noctua but why not water? ;)
A Lian Li TU100
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
A Lian Li TU100
I didn't say it was a waste... Water for everything I say :D
Awesome case, thinking of using one for a portable htpc.
Yeah its supposed to become my University/lan rig! :)
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
Sweet, I look forward to the build log.
Yeah but if people here think it's too fucked up i'll just go air and save some money for my main rig ;)
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
Eh, I wouldn't worry about what strangers on a forum think, a few even think cooling anything under a 4930K and triple titans is a waste of money *rolleyes*
:P
For your system, air cooling will do more than enough. Water cooling would cost more, have risks, and not do much more for performance; if you had SLI 760s, then it might be a different story, with more heat output.
Well i dont aim at gettin more performance. I also don't care if air cooling would be enough or if there are risks in wc or if its more expensive.
I only want the system to run a little cooler and maybe a little quieter than air. BUT with only one slim 120mm rad. If thats not possible i'll go air.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
