Test CPU Without Cooler?
Solved by Mateyyy,
So, even If in just booting it to see if I get to BIOS?
Yes, your CPU really needs cooling, even if you're not putting any load on it. If you're running it without a cooler, even in the BIOS, after a couple of minutes you will just fry your CPU, particularly if you will keep turning on your PC after the automatic shutdown from overheating.
kasdashd ·
1
6
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
