Hi all!
I'm building my first video editing PC for my cousin. I have bought most of the parts.
I need to buy the video card but still don't know which is the best option for her budget.
I was thinking if GeForce GTX 760 2GB it's the right choice. It justifies spending a few bucks more for the 4GB version?
It will be used mostly for Adobe Premiere Pro CS6.
Any recommendation will be appreciated.
https://linustechtips.com/topic/177209-first-workstation-build-help/
$300.
If you want to buy the GPU only, go for GTX760 2GB version
My current rig for entertainment/gaming: i5 4570 3,2GHz; MSI B85M-E45; ZOTAC GTX760 AMP!; 8GB (2x4GB) by Kingston; Seagate Barracuda 1TB 7200rpm; Corsair 200R, Corsair VS650; Dell U2312HM, Samsung DVD R/W optical drive; CM Devastator; Corsair MM400 gaming pad
Things I've already bought:
AMD FX-8350
GIGABYTE GA-970A-D3P
G.SKILL Sniper 16GB (2x8GB)
SSD Samsung 840 EVO 250GB
CORSAIR Carbide Series 200R
CORSAIR CX600 Power Supply
Okay so definitely GTX760 2GB this time
No more suggestions?
how much is the R9 280 in your country?
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
I buy from newegg and my courier in Miami send me to my country.
I have understood that NVidia is better for Adobe premiere pro and rendering...
Adobe have support for AMD cards using OpenCL
and the R9 280 is slightly faster for the same price as the GTX760
I think I'm going to buy ASUS ROG STRIKER GTX760 4GB
NO, DON'T, Asus's ROG branded GPU are much more expensive, get an evga SC ACX 760
Nvm the 4GB version they cost the same
