I have an AMD FX 8320 at 4.2 Ghz on stock voltage. Its current temp at P95 is 69 - 72C. I have a Cooler Master Hyper 212 Cooler with two fans and a Cooler Master Elite 431 Plus Cabinet. Is this temp real high ? I use an AS5 TIM. Any suggestions or help ? Thanks.
| CPU: Intel Core i5 8400 | Motherboard: MSI Z370 PC Pro | CPU Cooler: CM Hyper 212 PLUS | GPU: Zotac GeForce GTX 1070 AMP! Edition | RAM: G.Skill Aegis 16GB DDR4 2400 MHz | PSU: Corsair VS650 | SSD: SanDisk SSD Plus 120GB | HDD: Seagate Barracuda 2TB | Monitor: Dell S2240L | OS: Windows 10 Pro x64 |
https://linustechtips.com/topic/176911-cpu-temperature-issues/
Sure ? Its an 8320.
https://linustechtips.com/topic/176911-cpu-temperature-issues/#findComment-2373143
On other tests and intensive games its around 68C too.
https://linustechtips.com/topic/176911-cpu-temperature-issues/#findComment-2373145
Prime95 and you get 69C? Tha fack. Your chip is really cold.
69 - 72C.
https://linustechtips.com/topic/176911-cpu-temperature-issues/#findComment-2373148
That's pretty good, especially for a 212.
For a 212 it might be good but as far as the life of my CPU is concerned, is it good ?
https://linustechtips.com/topic/176911-cpu-temperature-issues/#findComment-2373240
Ok then. I was worried as some said it might damage it but I also saw in AMD site that the max for this cpu is 62C though. I want to OC it to 4.4 Ghz but is worried about temps.
https://linustechtips.com/topic/176911-cpu-temperature-issues/#findComment-2373263
69 is great.
I mean, a great temperature for your CPU.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/176911-cpu-temperature-issues/#findComment-2373268
https://linustechtips.com/topic/176911-cpu-temperature-issues/#findComment-2373282
