AMD CPU Stuck on my CPU Cooler. i cant remove it. please help ASAP
By
wefty
in Troubleshooting
in Troubleshooting
Solved by Maxwit44,
I generally take the fan off the heat sink, and boil the kettle, and fill a breakfast bowl with enough water to cover just over half of the heat sink. stand for about a minute the very carefully pick up the cpu only, comes straight off. either that or hold ont the cpu and try and lift every couple of seconds in case your scared of the heat.
Featured Topics
MiszS ·
Posted in New Builds and Planning15 -
Johnny Fehr ·
Posted in Windows3 -
4
12
4
14
3
