I want to direct connect my PC to my router but it is very far way. I thought i could just buy a very long (150ft-200ft) ethernet cable, wire it, and be fine. Then i was told that the longer the wire is the weaker the connection is going to be. Does anyone know if that is true or not?
Processor- Intel i7 4790k Ram- 16GB G.Skill Trident X 2400MHz Motherboard- ASUS Maximus VII Hero GPU- EVGA Geforce GTX 780Ti 3GB Storage- 1TB Western Digital Black + 256GB Samsung Pro SSD PSU- Corsair HX750 Cooling- Corsair H100i
Operating System- Windows 8.1 Pro 64bit Case- Cosrsair Obsidian 450D Display- ASUS VX238H Mouse- Corsair Vengeance M65 Keyboard- CM Storm QuickFire TK
https://linustechtips.com/topic/174834-long-ethernet-cable/
Hi there, the answer is yes, the longer the cable, the weaker the connection is going to be. This has to do with resistance, the longer the wire the more it will resist electricity from flowing through the cable.
Here is a link to a more specific explanation about it http://en.wikipedia.org/wiki/Electrical_resistance#Relation_to_resistivity_and_conductivity
About the ethernet cable, I think that it is still not that much resistance that it will have such a big impact on connection quality, matter will get worse when you are running cables in a very very long distance.
I need to work hard because I realized my toys are not cheap.
https://linustechtips.com/topic/174834-long-ethernet-cable/#findComment-2327321
Although it's true the resistance is so negligible. I've tested this with a 3ft cable I borrowed from my friend and with a 100ft cable my housemates had casually lying around when I moved in. Both cables gave me the full 50mbps down my ISP provides.
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/174834-long-ethernet-cable/#findComment-2327433
In theory yes there will be deterioration as you increase distance but for that short of a run you should be fine. My house is fully wired with Cat5e and I have about 100 ft in cable between my modem and PC and I get near Gigabit speeds when transferring internally to a NAS.
CPU: Intel I7-4790k | MOBO: Asus Sabertooth Z97 Mark 1 | Ram: Corsair Vengance 32GB 1600hz | GPU: EVGA GTX980 Reference
PSU: Corsair EVGA G2 850W  | SSD: Intel 730 Series 480GB, Kingston SSDNow V300 120GB | HDD: WD Black 1TB
 CPU Cooler: Corsair H105 | Case: Corsair 760T (White) | Peripherals: (2)Asus VS247H-P, Corsair M65, Corsair K70 RGB w/ Brown Switches
https://linustechtips.com/topic/174834-long-ethernet-cable/#findComment-2327461
You'll be fine. My computer is connected through cat5e with a 200ft wire and I'm getting full speeds.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/174834-long-ethernet-cable/#findComment-2327497
thanks everyone, now i just have to figure out how im going to wire this cable
https://linustechtips.com/topic/174834-long-ethernet-cable/#findComment-2328070
The max length on any of the wires is 100m, and Cat5e and better will carry 1 gbps at that distance.
Upgrade to Cat6 if you are running it near a lot of power (in a house you aren't... I mean a LOT of power.) I have 280' of Cat5e zip tied to metal conduit along the service entrance of a 400 amp panel for about 60', then zip tied to a conduit for 100 amp over near a welder for the majority of the remaining distance, and then it goes for a little ways on a conduit with some 20 amp circuits and into a switch. It has been like that for 4 years and I've never noticed any issues with speeds.
Upgrade to Cat6a if you want 10gbps in the future at that distance.
IIRC, Cat5e will carry 10gbps for 10m, Cat6 will carry it for 30m.
https://linustechtips.com/topic/174834-long-ethernet-cable/#findComment-2336652
CAT5e should be good at gig speeds for around 100 meters. After that it will degrade.
CPU: i7 3770k @ 4.8Ghz Motherboard: Sabertooth Z77 RAM: 16GB Corsair Vengeance GPU: GTX 780 Case: Corsair 540 Air Storage: 2x Intel 520 SSD Raid 0 PSU: Corsair AX850 Display(s): 1x 27" Samsung Monitor 3x 24" Asus Monitors Cooling: Swifttech H220 Keyboard: Logitech 710+ Mouse: Logitech G500 Headphones: Sennheiser HD 558 --- Internet: http://linustechtips.com/main/uploads/gallery/album_1107/gallery_12431_1107_23677.png My Setup:  http://linustechtips.com/main/gallery/image/7922-1-rkcf7io/ -- NAS: 3x WD Red 3TB Drives (RAIDZ-1), 5x 750gb Seagate ES HDD(RAIDZ-1), 120gb SSD for caching, OS: FreeNAS --  Server 1: Xeon E3 1275v2, 32GB of RAM, OS: ESXi 5.5 -- Server 2: Xeon E3 1220v2, 32GB of RAM, OS: ESXi 5.5
https://linustechtips.com/topic/174834-long-ethernet-cable/#findComment-2337652
You should use an STP (Shielded) cable instead of UTP for these kind of interferences.
https://linustechtips.com/topic/174834-long-ethernet-cable/#findComment-2337654
Ethernet cable shouldn't be ran along side high-voltage wiring, unless shielded.
https://linustechtips.com/topic/174834-long-ethernet-cable/#findComment-2337690
also only ground 1 side for shielded cables
grounding both sides will make the shielding null and void and turn it into a fire hazard
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/174834-long-ethernet-cable/#findComment-2337726
All network outputs that are made right follow a spesification, this calls for the signal to work at 90 meter + 2 patchcords at each end at 5meter, for a totalt of 100meters between sockets.
I have used a 124 meter long Cat 5 cable once, which worked fine, even if it was laying next to 230v cables all the way. But at 134 meters it didn't work. Solution, but a switch at 124 meters, and the rest of the length then wasn't a problem.
Sorry for the few off Capital letters in my posts, it does it on its own when I Write in English, since my OS is in another Language. It's annoying.
https://linustechtips.com/topic/174834-long-ethernet-cable/#findComment-2339216
You'll be fine. My ethernet cable is something like 50 feet. (Maybe more. I forget.)
The only reason it runs at 100MBs and not 1Gbps is because I have to use an old PCI ethernet card because the onboard Realtek crapped out. (Stuck in deep sleep mode.) Still better than WiFi.
NZXT Phantom|FX-8320 @4.4GHz|Gigabyte 970A-UD3P|240GB SSD|2x 500GB HDD|16GB RAM|2x AMD MSI R9 270|2x 1080p IPS|Win 10
Dell Precision M4500 - Dell Latitude E4310 - HTC One M8
$200 Volvo 245
https://linustechtips.com/topic/174834-long-ethernet-cable/#findComment-2339301
