Hello guys! I just wanna know why is our wifi faster from our LAN? I'm using wifi right now and I get better speeds. While I use LAN, I get slower speeds comparitevely. Why is it like that? I've seen this happen in many places. Can anyone explain?
 [spoiler=CORMAC]CPU:Intel celeron 1.6ghz RAM:Kingston 400mhz 1.99gb MOBO:MSI G31TM-P21 GPU:Will add one later on! CASE:local ROUTER D-Link 2750U, D-LINK 2730U MOUSE:HP,DELL,ViP KEYBOARD: v7 SPEAKERS:Creative 245  MONITOR:AOC E970Sw HEADSET: Sony MDRx05s UPS:conex ups avr 500va PSU:idk OD:Samsung super writemaster STORAGE:80 gb seagate+ Seagate 1TB OS:Windows xp sp3 themed to Windows 7 + Linux |Rest all pc in my house will be updated from time-time
COMING SOON
https://linustechtips.com/topic/173263-wifi-faster-than-lan/
What do you mean? Are you talking about ping between you and another computer/server on LAN while playing games or something? Or like, download speeds on LAN?  :blink:
I really wish that we'd just make organic hardware already, that grows and adapts to the demands it needs to meet. That way, grannies' computers can be floppy sacks of organicness and the 12 year old Minecrafters will look like the guys that only do bicep curls, and the nerdy programmers will finally have justice, with their body-builder rigs that skipped leg day.
CPU: i7-4770k 4.8GHz | Motherboard: Asus Maximus Hero | RAM: 16gigs 2133MHz | GPU: SLI Gigabyte OC 2gb 770's | Case: INWIN GRone | Storage: 1tb Blue, 60gb SSD | PSU: Silencer MK II 950w | Cooling: Modded H100i
https://linustechtips.com/topic/173263-wifi-faster-than-lan/#findComment-2301823
. Ping.
COMING SOON
https://linustechtips.com/topic/173263-wifi-faster-than-lan/#findComment-2301826
Sometimes bad ethernet drivers can cause this
This. If you're plugged in, it could be outdated drivers, or simply bad ones. Age of Empires 2 was impossible to LAN back when I was just using my laptop, because of horrible drivers giving me a ping of 400. Had to use wireless and Hamachi to LAN, until HP came out with drivers after my damn laptop melted. >.<
https://linustechtips.com/topic/173263-wifi-faster-than-lan/#findComment-2301833
Regarding that sometimes,I have a cat 6 cable run in my house. Not very huge distance, just to 4 other rooms and my room, and the media room. Is that a problem?
COMING SOON
https://linustechtips.com/topic/173263-wifi-faster-than-lan/#findComment-2301837
Theoretically wifi should not be faster than a wired connection. Bad drivers or a cheap cable ( or a cable too long) will obviously lose to high quality wifi though.
https://linustechtips.com/topic/173263-wifi-faster-than-lan/#findComment-2301840
can you tell me how to do that? I wanna try it out too!
COMING SOON
https://linustechtips.com/topic/173263-wifi-faster-than-lan/#findComment-2301841
Uhm. Open up Hamachi (unmanaged one), create a server, have people join that server (they do not need to be on the same network as you), and then use the IP from the Hamachi server as your LAN IP when the game/client, or whatever you're doing, asks for it. It's mainly used for playing LAN games when the person is not on the same network as you.
https://linustechtips.com/topic/173263-wifi-faster-than-lan/#findComment-2301849
What ethernet cable are you using?
D-Link cat 6 ethernet cable.
COMING SOON
https://linustechtips.com/topic/173263-wifi-faster-than-lan/#findComment-2301935
Try using a different cable or updating drivers.
Alright. I have another cable (cat5). I think i'll try that one.
COMING SOON
https://linustechtips.com/topic/173263-wifi-faster-than-lan/#findComment-2302158
Cat5 is only up to 100Mbit. Cat6 is up to 1Gbit.
https://linustechtips.com/topic/173263-wifi-faster-than-lan/#findComment-2306538
I don't need 1Gbit here. I think cat5 is good enough.
COMING SOON
https://linustechtips.com/topic/173263-wifi-faster-than-lan/#findComment-2307280
