Will it "Bottleneck" my pc
Go to solution Solved by Guest,
Nope, it's a six core FX 6300 bought from amazon and nope it's under a Hyper 212 EVO. Maybe if I upgrade to Windows 8 it'll get better.
Ofcourse! That's the problem, BF4 sucks under Windows 7, trust me, install windows 8 and dips will disappear and you will get at least 20 more FPS!
https://linustechtips.com/topic/166255-will-it-bottleneck-my-pc/
i5 4690k and a 650W PSU
https://linustechtips.com/topic/166255-will-it-bottleneck-my-pc/#findComment-2212574
He's mainly going to be gaming, it's a waste of money.
an i5 will perform much better in gaming than any AMD CPU
https://linustechtips.com/topic/166255-will-it-bottleneck-my-pc/#findComment-2212576
Please...
Grab the 8320 @xkingalexx
Le Bastardo+
i7 4770k + OCUK Fathom HW labs Black Ice 240 rad + Mayhem's Gigachew orange + 16GB Avexir Core Orange 2133 + Gigachew GA-Z87X-OC + 2x Gigachew WF 780Ti SLi + SoundBlaster Z + 1TB Crucial M550 + 2TB Seagate Barracude 7200rpm + LG BDR/DVDR + Superflower Leadex 1KW Platinum + NZXT Switch 810 Gun Metal + Dell U2713H + Logitech G602 + Ducky DK-9008 Shine 3 MX Brown
Red Alert
FX 8320 AMD = Noctua NHU12P = 8GB Avexir Blitz 2000 = ASUS M5A99X EVO R2.0 = Sapphire Radeon R9 290 TRI-X = 1TB Hitachi Deskstar & 500GB Hitachi Deskstar = Samsung DVDR/CDR = SuperFlower Golden Green HX 550W 80 Plus Gold = Xigmatek Utguard = AOC 22" LED 1920x1080 = Logitech G110 = SteelSeries Sensei RAW
https://linustechtips.com/topic/166255-will-it-bottleneck-my-pc/#findComment-2212591
so he should go for a i5.. and considering they cost as much and its WAY better than a 6 core amd... which is totally useless and slower... so what do you mean its a waste of money? his or my suggestion?
Proud Member of the Glorious PC Master Race
https://linustechtips.com/topic/166255-will-it-bottleneck-my-pc/#findComment-2212622
Not true, in games like Battlefield 4 there is not a significant difference between fx 6300 vs 3770k, only games that benefit are crysis 3 and metro last light.
Actually, I'm going to get into this because I'm really unhappy with the performance I've gotten with my FX 6300 in Battlefield 4. My frames would sometimes dip down to the 40s sometimes even 38 or so and that's pretty noticeable, I hated playing BF4. Thankfully AMD's Mantle came to save the day, now I rarely dip below 60 in high settings also with a 270X. This clearly shows I need a bit more CPU power. I'd get the FX 8320 it's only a few more bucks.
https://linustechtips.com/topic/166255-will-it-bottleneck-my-pc/#findComment-2212641
As having seen an almost exact build to this myself, it runs well.
thanks that the advice i was looking for, as long as it gets over 30fps on vhigh/ ultra which the card does i can play, anyway i not using a 1080p moniter its 1600x900 and i am not changing for a while. thanks
https://linustechtips.com/topic/166255-will-it-bottleneck-my-pc/#findComment-2212663
Oh easily, though you may want to take a look at the 270 non x card. It's essentially the same card but cheaper.
https://linustechtips.com/topic/166255-will-it-bottleneck-my-pc/#findComment-2212673
