Hello i am getting bad frameshy and i finally discoverd why.... It is using interagated graphics. How do i change it. I tired nvidia control panel but it keeps switich back to auto select. Here is specs
OS Name Microsoft Windows 8
Version 6.2.9200 Build 9200
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name MATTLCPDFR
System Manufacturer Alienware
System Model M14xR2
System Type x64-based PC
System SKU xxx123x#ABA
Processor Intel® Core i7-3610QM CPU @ 2.30GHz, 2301 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date Alienware A09, 6/29/2012
SMBIOS Version 2.7
Embedded Controller Version 1.01
BIOS Mode Legacy
BaseBoard Manufacturer Alienware
BaseBoard Model Not Available
BaseBoard Name Base Board
Platform Role Mobile
Secure Boot State Unsupported
PCR7 Configuration Binding Not Possible
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "6.2.9200.16384"
User Name Mattlcpdfr\Matt
Time Zone Pacific Daylight Time
Installed Physical Memory (RAM) 8.00 GB
Total Physical Memory 7.88 GB
Available Physical Memory 6.03 GB
Total Virtual Memory 15.9 GB
Available Virtual Memory 13.9 GB
Page File Space 8.00 GB
Page File C:\pagefile.sys
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes
https://linustechtips.com/topic/165604-alienware-m14x-graphics-card-help/
System Model M14xR2
SMBIOS Version 2.7
BIOS Mode Legacy
check power settings
make sure you are plugged in and set to high performance
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
Are you sure it actually came with one
I wouldnt be sure considering its AlienWare
FANBOY OF: PowerColor, be quiet!, Transcend, G.Skill, Phanteks
FORMERLY FANBOY OF: A-Data, Corsair, Nvidia
DEVELOPING FANBOY OF: AMD (GPUS), Intel (CPUs), ASRock
Look up the model number, it comes with a discrete GPU.
Personal Rig v3: AMD Ryzen 7 2700X | Noctua NH-U14S | Gigabyte B450 Aorus Pro ITX | Zotac GTX 2070 8GB | 16GB G-Skill Trident DDR4 3200MHz | EVGA Supernova 750B | Phanteks Enthoo Evolv ITX
Peripherals: Sennheiser HD518 & Classic ModMic | Corsair K65 Luxe | Zowie EC2 | ASUS VG259QM  |  ASUS VG278E | Klipsch ProMedia 2.1
it has a weak GPU
Nvidia GeForce GT 650M  :mellow:
