Windows Vista
Current rig: CPU: AMD FX-8120  Cooling: Corsair H100i  Mobo: ASRock 970 Extreme 3  RAM: 8GB 1333Mhz  GPU: MSI GTX 660Ti Power Edition  Case: Fractal Design Define R4  Storage: 2TB Seagate HDD + 128GB Crucial SSD  PSU: be quiet! 730W bronze
https://linustechtips.com/topic/165274-operating-system/#findComment-2199384
Options are Windows 8.1, Windows 7, Linux, or Mavericks.
Win8.1 sounds like the best options as its the newest of them all
MotherBoard: Asus Z87 Gryphon CPU: i5 4670k CPU Cooler: NZXT Kraken X41 GPU: Asus Radeon R9 290 DCUII RAM: Kingston HyperX Fury 1866 2x4GB
PSU: Corsair HX650v2 SemiModular Storage: Kingston HyperX 3k 120GB, Seagate Barracuda 2TB Case: Corsair Obsidian 350D mATX Monitor: Samsung S24D590PL Keybord: Ducky Shine Zero Cherry  Red Mouse: Corsair Raptor M45
OS: Windows 8.1
https://linustechtips.com/topic/165274-operating-system/#findComment-2199393
Ya but I heard the layout is horrible with the quick corners so it always brings you to the start menu with it only touching for a millisecond<<<(exaggeration)
https://linustechtips.com/topic/165274-operating-system/#findComment-2199402
u can disable the hot corners. it came with the update Win8.1
OS: Windows 8.1
https://linustechtips.com/topic/165274-operating-system/#findComment-2199418
It's a great OS. You can simply disable the quick corners if you want to, not problem there. In fact, there are a lot of settings to make the system behave more like Windows 7 so it's perfectly suited for a desktop computer rather than a tablet. Get Windows 8.1 and pin all the stuff you use to the start screen and try it out like it was intended to be used before installing 3rd party software. If you approach it with an open mind you will never look back.
https://linustechtips.com/topic/165274-operating-system/#findComment-2199433
buy start is back for about 1$ and you'll have a normal startmenu ^^
Frost upon these cigarettes.... lipstick on the window pane...
https://linustechtips.com/topic/165274-operating-system/#findComment-2199442
why buy start is back if classic start has a bunch of customization functions and it's free? you can even choose what layout of the start menu you want to use.
anyway, I use win 7 because I have a lot of custom themes and I hate the look of the startup screen on windows 8 and am not in the mood to customize a new OS if I don't have any problems with my current.
CPU: R5 1600 @ 4.2 GHz; GPU: Asus STRIX & Gigabyte g1 GTX 1070 SLI; RAM: 16 GB Corsair vengeance 3200 MHz ; Mobo: Asrock Taichi x470; SSD: 512 gb Samsung 950 Pro Storage: 5x Seagate 2TB drives; 1x 2TB WD PurplePSU: 700 Watt Huntkey; Peripherals: Acer S277HK 4K Monitor; Logitech G502 gaming mouse; Corsair K95 Mechanical keyboard; 5.1 Logitech x530 sound system
 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01100100 01101111 01100101 01110011 01101110 00100111 01110100 00100000 01101101 01100001 01101011 01100101 00100000 01111001 01101111 01110101 00100000 01110000 01110010 01101111 00101110
https://linustechtips.com/topic/165274-operating-system/#findComment-2199532
Windows 8.1
https://linustechtips.com/topic/165274-operating-system/#findComment-2199553
BC start is back is not a process, it's integrated as the old one was, so can't crash.
https://linustechtips.com/topic/165274-operating-system/#findComment-2199679
Windows 8.1, Windows 7, Ubuntu or Windows 95
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/165274-operating-system/#findComment-2199731
just because it is infused into explorer.exe doesn't mean explorer.exe can't crash, it happens a lot on the computers of the illiterate. (this goes for both)
https://linustechtips.com/topic/165274-operating-system/#findComment-2201080
What kind of op system should I use for my new PC build... Any suggestions.
Windows 2000 Professional.  I have the floppy disks right next to me if you need to borrow them.
Desktop: Intel Core i7-6700K, ASUS Z170-A, ASUS STRIX GTX 1080 Ti, 16GB DDR4 RAM, 512 GB Samsund 840 Pro, Seasonic X series 650W PSU, Fractal Design Define R4, 2x5TB HDD
Hypervisor 1: Intel Xeon E5-2630L, ASRock EPC612D8, 16GB DDR4 ECC RAM, Intel RT3WB080 8-port RAID controller plus expansion card, Norco RPC-4020 case, 20x2TB WD Red HDD
Other spare hypervisors: Dell Poweredge 2950, HP Proliant DL380 G5
Laptops: ThinkPads, lots of ThinkPads
https://linustechtips.com/topic/165274-operating-system/#findComment-2201131
My best suggestion is try them all out before you pony up any cash to buy one.
Download the 8.1 Evaluation copy then build your PC and install it on it play around with it for as long as you like (90 days before it runs out) see what you think.
Download a Windows 7 iso and do the same, and download a linux distro (like Ubuntu) and do the same.
You don't even have to wait, if you have a spare blank HDD then 'burn' the OS you want to a USB or DVD, shut down your PC and remove all your HDDs, attach the blank HDD and install the OS on there to try out, after shut down remove the HDD and reattach your previous HDDs like you removed them, everything will be back to normal.
https://linustechtips.com/topic/165274-operating-system/#findComment-2203940
why is this even a question?
for gaming windows8.1 or 7 if you are a hater of the modern ui
if you are not a gamer and like open source stuff and the hazel it comes with then a distribution of linux, get Ubuntu  if you are a noob.
and do a Hakintosh build if you absolute want Mac OSX
https://linustechtips.com/topic/165274-operating-system/#findComment-2203981
