Okay so I just got my first job (I start tomorrow) I work for the IT department at our school, I will be getting paid minimum wage I will be working from 7 - to 3
Any general tips about a first job you should give me would be awesome.
https://linustechtips.com/topic/164900-first-job/
Have fun ;)
Case: Corsair Carbdie 330R Motherboard: Gigabyte GA-970A-DS3P Asus Z97-A CPU: AMD FX-6300 i5 4690K 3.5 GHZ + 212 EVO GPU: ASUS GTX 760 DirectCUII Ram: Corsair Vengeance LP 8gb (2x4gb) HDD: Seagate Barracuda 1TB PSU: Corsair CX500M
Monitor: AOC Q2963pm 29'' 21:9 IPS Mouse: Mionix Naos 8200 Mousepad: Mionix Sargas 320 Headset: HyperX Cloud Keyboard: Corsair Gaming K70 RGBIKEA Headset/Headphone Holder
https://linustechtips.com/topic/164900-first-job/#findComment-2194476
You'll be paying minimum wage or you'll get paid minimum wage?
There is a massive difference :P
https://linustechtips.com/topic/164900-first-job/#findComment-2194484
ProTip: Dont molest the children
don't try to hook up with your clients too  :lol:
https://linustechtips.com/topic/164900-first-job/#findComment-2194486
lol, yes I am paying people for me to have  a job. XP
https://linustechtips.com/topic/164900-first-job/#findComment-2194497
Ask questions to clarify things and to show you're actively listening, don't spout off that you know things or how to do something if someone is showing you how to do something.
Intel 4670K /w TT water 2.0 performer, GTX 1070FE, Gigabyte Z87X-DH3, Corsair HX750, 16GB Mushkin 1333mhz, Fractal R4 Windowed, Varmilo mint TKL, Logitech m310, HP Pavilion 23bw, Logitech 2.1 Speakers
https://linustechtips.com/topic/164900-first-job/#findComment-2195080
Work hard and only accept the job if it is truly the one you can and will do. I applied for a job at a care home a while back $23 and hour pay at 18 years old is not bad. I hated it only stayed 9 months then quit, it was just a lousy job. The people including my boss loved me so it ended up ok and she understood. The moral of the story is make sure you are willing to what you singed up for.
https://linustechtips.com/topic/164900-first-job/#findComment-2196075
