Glad i'm not crazy. Would switching pci slots affect it at all?
it's because of the 40c delta T on idle and 60c delta T on load.
it should be about 20~c and 60-70c delta T
I don't think scwitching is going to affecting it.
i7-4790k | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | MX100 256gb     | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 White
G3258    | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | 4 x 3TB WD Reds | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 Black
i7-965EE | Rampage II Extreme | Kingston HyperX Fury 16gb | CM M2 700w | Sapphire Nitro 380 4GB
https://linustechtips.com/topic/163763-crazy-290x-temps/page/2/#findComment-2178866
What driver are you using now? From what I've gleaned from the net, the latest 14.6 driver raises GPU temps by 3C - 5C, upon install, I did notice my GPU idle temps were higher. The previous drivers had this stuck in 3D clock bug even though the GPU is idling, but it did not affect everyone who had installed it. Mine was though, my dual R9 290X would stick to 1100mhz core evn on desktop. The latest driver resolved that issue for me, but raises temps a little....btw, Sapphire Tri-X is good enough, Vapor X is better while Toxic is just plain awesome.
At above post:
Yeah, something wonky here, is the fan spinning?
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
https://linustechtips.com/topic/163763-crazy-290x-temps/page/2/#findComment-2178950
I think that was the problem. I manually set the fan speed and it went to 38c idle.
They were spinning though but I guess they barely were?
And I'm using 14.6
Have you coreected the fanspeed setting? Perhaps that explains your high temp......adjust it and check temp.
https://linustechtips.com/topic/163763-crazy-290x-temps/page/2/#findComment-2179056
Ahhhh, problem solved w/o the hassle of RMA. Sometimes, users reset fanspeed w/o realizing it......~40C while idling is decent enough.
https://linustechtips.com/topic/163763-crazy-290x-temps/page/2/#findComment-2179108
