im currently have an SLI setup in my rig.
Card 1: Nvidia Geforce EVGA 9800 GTX
Card 2: Nvidia Geforce EVGA 9800+ GTX
Under my Device manager for the second card the 9800+
It says its a 230 GT ??
And If I try and change the Fan speed with any card tweaking software it crashes my system and
get a blue screen
Specs:
MOBO: Asus A8n-sli premium
Processor: AMD Athlon 64 X2 3800+
Ram: 4GB Kingston
I have tried Both card By them selves and when I do they are both named the RIght name
9800 and the 9800+
But when in SLI second card the 9800+ is marked as 230GT.
 I have tried installing and uninstalling the latest drivers and used Geforce Experience and Also manually. still the same result.
What do I do ??
https://linustechtips.com/topic/162452-sli-help/
I say do a complete uninstall of the nVidia drivers once more
but try swapping the position of the GPU
so it will be this
re-seat the GPU and the SLi bridge
and report us the result
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/162452-sli-help/#findComment-2162360
Buy a newer graphics card? It seems like you have tried everything that could be a problem. I'm guessing the cards are just too old, or have compatibility issues with themselves.
https://linustechtips.com/topic/162452-sli-help/#findComment-2162361
What drivers are you using? Those are old cards. If using the newest, back down the drivers to previous versions. Rinse and repeat until the proper SLI combo is recognized.
AMD FX-8350 @ 4.7Ghz when gaming | MSI 990FXA-GD80 v2 | Swiftech H220 | Sapphire Radeon HD 7950  +  XFX Radeon 7950 | 8 Gigs of Crucial Ballistix Tracers | 140 GB Raptor X | 1 TB WD Blue | 250 GB Samsung Pro SSD | 120 GB Samsung SSD | 750 Watt Antec HCG PSU | Corsair C70 Mil Green
https://linustechtips.com/topic/162452-sli-help/#findComment-2162362
so it will be this
OK. have tried the complete uninstall of drivers but havent tried switching them
ok I dont have money for that. And anyone else telling me that Dont post that
https://linustechtips.com/topic/162452-sli-help/#findComment-2162371
whoops now i remember
the newer nVidia drivers have drop support of older GPU series so it might be this issue
https://linustechtips.com/topic/162452-sli-help/#findComment-2162373
Yes, you are right. Anything older than the GTX400 series is no longer supported by Nvidia
So the only solution is to use only one graphics card, or buy a new card.
https://linustechtips.com/topic/162452-sli-help/#findComment-2162392
-_________________________- youve got to be shitting me. wait does anyone know what version I could scale down to that has support and if so could you plz provide a link
https://linustechtips.com/topic/162452-sli-help/#findComment-2162655
