It's constantly using 1 - 1.5% CPU... I know exactly when it started, but several PC restarts and it's still stuck doing this...  I deleted a bunch of mods and the last item took forever (I waited 10 minutes) and I already saw in taskmanager it's "system" that got stuck... so I randomly closed the delete progress bar, and since then "ntoskrnl.exe" is apparently stuck trying to delete this file...
And 1.5% is definitely not normal, my CPU usage while idle has always been 0.1 - 0.5% (even with apps open) but now it's 2% with ntoskrnl using up 1.5% (forever basically?)
Any way to stop this process? (the stuck "delete" process i mean, i know you you can't stop ntoskrnl, unfortunately...)
-Scott Manley, 2021
https://linustechtips.com/topic/1614210-ntoskrnlexe-stuck/
You'd essentially be killing the OS from running. That's more or less your kernel process.
https://en.wikipedia.org/wiki/Ntoskrnl.exe
What do you mean by mods? What modifications have you done to this install?
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1614210-ntoskrnlexe-stuck/#findComment-16742963
I know but I think there's another process that's causing this (aka probably taskmanager) ntoskrnl shouldn't even run after startup... yet it does suddenly now.
Mods..... street fighter 6 mods to be specific... I just mentioned it because mods often come with weird or long names and that sometimes makes them difficult to delete for windows,but this has never been an issue so far, until now.
-Scott Manley, 2021
https://linustechtips.com/topic/1614210-ntoskrnlexe-stuck/#findComment-16742969
You could take a look in Process Explorer to see if it can ID the specific thread that's doing it. You may have to get the Windows debugging symbols to get an accurate fix on what it's doing.
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
https://linustechtips.com/topic/1614210-ntoskrnlexe-stuck/#findComment-16742970
Still need to get the game tho after I get smt that can run it 🥲
I edit my posts for so if you saw a typo.... no you didn't, you are just crazy
https://linustechtips.com/topic/1614210-ntoskrnlexe-stuck/#findComment-16743020
It's the Kernel, of course it has to run after startup. Its the core of the Windows OS. It's normally shown as "System" in Task Manager, but if you go to details, you can see that it's ntoskernel.exe
It may be doing work for some other process, so the usage you see may be caused by something else indeed.
https://linustechtips.com/topic/1614210-ntoskrnlexe-stuck/#findComment-16743023
Yeah that's what I'm thinking... Maybe this failed delete operation triggered it or maybe it didn't, I just don't understand why it doesn't stop,hence it appears to be stuck - I'll try with these monitoring options, I mean "something" has to cause it.
I guess I meant noticably, I've never seen it hog up the top spot like this and I monitor this quite a lot... constantly around 1.5% , more than all other processes together - and it's still doing it...
4 hours ago, Haswellx86 said:
Check Resource Monitor and see if ntoskrnl.exe is doing some drive I/O. If so, look where.
Idk how to check the I/O but I think it's "searchapp.exe"?
Aka it's searching the file it couldn't delete, but deleted anyways (I mean the file is clearly gone)
Stupid windows... So do I just end this task?
Edit: nah, ending that task didn't change anything, system still at 1-1.5% constantly
-Scott Manley, 2021
https://linustechtips.com/topic/1614210-ntoskrnlexe-stuck/#findComment-16743213
In the disk tab and opening one of the sections you can find the processes and where they are doing drive I/O. ntoskrnl is generally present and probably doing stuff with like the drive MFT and all.
searchapp.exe could be the Windows search and probably could be indexing it but not sure. Indexing has its own processes I think.
Yes, you can end that task. End tasks which are using resources when you aren't doing anything. Like the famous Microsoft Telemetry something something. Wakes up anytime on its own, and starts eating a full CPU thread doing god knows what. I used to end it, but these Microsoft products are delicate and corruption is easy. You should just give them time and let them do whatever they want. And at this point you would know why Linux seems an awesome thing to switch to.
ntoskrnl.exe could be doing something else as well. 1-1.5% means it isn't even close maxing out one of your CPU threads (if you have 16 threads on your 5800X3D). Make sure nothing else is going on like updates and all. And you could always try booting into safe mode and see if that goes away.
PLEASE MARK COMMENTS AS SOLUTION IF SATISFIED!!
bigger number better, makes me look cooler.
https://linustechtips.com/topic/1614210-ntoskrnlexe-stuck/#findComment-16743225
