BF4 patch finally fixes netcode issues!!!!
The public version of the CTE's higher tickrate update has finally arrived! Screen shake has been decreased. Many other bugs have been fixed. Get it now!
Article:
http://blogs.battlefield.com/2014/06/new-netcode-update-rolling-out/
Patch notes:
http://battlelog.battlefield.com/bf4/forum/threadview/2955065219584248915/
It is a nescessary update that will automatically download once you aunch BF4 from Origin.
https://linustechtips.com/topic/161296-bf4-patch-finally-fixes-netcode-issues/
Ayyy it only took 8 months for them to partly fix their game :)
Its so much better now holy shit, i just went ape shit on a server.
This is odd the main problem this whole time wasnt a bug, just a stupid decision made by someone on the team.
Listen if you care.
Can someone tell me what net code is?
CPU AMD FX 8350 @5GHz. Motherboard Asus Crosshair V Formula Z. RAM 8GB G.Skill Sniper. GPU Reference Sapphire Radeon R9 290X. Case Fractal Design Define XL R2. Storage Seagate Barracuda 1TB HDD and 120GB Kingston HyperX 3K. PSU XFX 850BEFX Pro 850W 80+ Gold. Cooler XSPC RayStorm
never had a problem before....
msi z97m gaming - i5 4690k @4.4ghz 1.2V corsair h110 powercolor r9 290x pcs+ - 8GB corsair vengeance dual channel @2133mhz - thermaltake smart power se 730watts - intel 530 series 240GB ssd seagate 1tb 7200rpm - corsiar obsidian 350D - 2x enermax tb silence 140mm - logitech x-530 - sony mdr xb600 - medion 24'' 1080P cm storm quickfire tk white edition with cherry mx red cheap but awesome mouse #GloriousPaintMasterRace
I'm sure they can't mess up Mass Effect 4 any more than they messed up the last 15 minutes of Mass Effect 3.
I have no clue why everyone hated the ending. I've played through the series five times and love them more each time I do.
My previous 4P Folding & current Personal Rig
I once was a poor man, but then I found a crown.
Add this video to your OP
From Battlefield themselves.
The High Frequency Update is by default turned OFF in this release.
You will have to enable this setting to take advantage of the improved networking.
To support players with a limited bandwidth connection, we support three different levels: LOW, MEDIUM and HIGH.
Most players with a connection faster than 1Mbit should be fine using the HIGH setting.
If you experience any issues, lower or turn off the setting completely.
The netcode is exactly that, the information going back and forth between the server your connected to, and the client your playing on.
Not withstanding all the other players on the map having their connections too.
With the server updating information only 10x a second, it was not getting all the information required (all the objects moving, bullets and projectiles) sent and recieved in timely fashion.
The netcode has been the blamed cause for BF4's issues, and this patch has some changes "for the better" in regards to this updating.
You can youtube/google it more if you want, but the server updates too slow, and game appears broken or with heavy unfluential issues in that state.
So their making it better.
Update Details
PC
• Improved/reduced explosion induced camera shake
• Character collision improvements
• Fix to reduce object damage mismatch between client/server.
• Fix explosion packs not being able to be shot sometimes
• Improvements for client side packet loss
• Client crash fixes
• AMD Mantle multi-GPU improvements
• Carrier Assault game mode reports bug fix
• High Frequency Network update
- Added High frequency “bubble” updating player movement, stance, rotation, damage and projectiles at a separate rate on foot and in vehicles
- Added option to control client side update rate setting
PlayStation 3
• Rental server bug fixes
• Reduced object damage mismatch between client/server.
• Fix for explosion pack not being able to be shot sometimes
• Added controller option to swap functionality of the bumper and trigger buttons
• Carrier – Invisible walls stopping bullets fix
Xbox 360
• Rent A Server bug fixes
• Physics optimization for Naval Strike Wave Breaker rocks
• Fix for issue where clients with low bandwidth would not be able to enter squad menu.
PlayStation 4
Xbox One
• Fixed issue when using standby in Campaign
• Fixed issue when using standby and reconnecting to game servers
• Fixed issue with snapped application and matchmaking
• Playgroup Matchmaking fix for Xbox One
• Fixed incorrect error message for lost Xbox Live connection
• Fixed issue for user name mismatch in rental server, ingame scoreboard and Squad Join menus
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
Pretty sure this means they will announce the next game in the series now.
The stone cannot know why the chisel cleaves it; the iron cannot know why the fire scorches it. When thy life is cleft and scorched, when death and despair leap at thee, beat not thy breast and curse thy evil fate, but thank the Builder for the trials that shape thee.
They already did:
I should have known...
It may have had something to do with them introducing God and completley changing the whole universe as we knew it in the final moments of the game. It was their attempt at a twist ending and they fucked everything up.
Basically a way to sync everyone and everything in a server with eachother so that what everyone sees is happening as accurately as possible.
If you've ever claimed to have been shot through a wall in BF4 then you've experienced the poor netcode (until now). On your screen you clearly went behind the wall, but because it's not in sync with the person who killed you, on their screen you were not behind the wall yet.
I wonder if players with high ping (like me, because of where I live) will get kicked out of the servers now. That's what held me back from buying it.
Can't you join servers closer to you?
Awesome
CPU: I7 3770k @4.8 ghz | GPU: GTX 1080 FE SLI | RAM: 16gb (2x8gb) gskill sniper 1866mhz | Mobo: Asus P8Z77-V LK | PSU: Rosewill Hive 1000W | Case: Corsair 750D | Cooler:Corsair H110| Boot: 2X Kingston v300 120GB RAID 0 | Storage: 1 WD 1tb green | 2 3TB seagate Barracuda|
Just in time for their new game, which you can pre-order now! Money gabbing bastards
Took a year to fix Simcity, what's new with EA? I hope they don't screw up Mass Effect 4
That ship already sailed with ME3 and the introduction of microtransaction.
Amen
You mean aside from the fact that apart from your choice of how you look, it completely invalidates every choice you ever made in ME1 & 2, and boils the ending down to a matter of which colour you'd like to see it in?
Fractal Design R2 Define, Core i5-4670k@3.40Ghz, 16gb Corsair Vengeance Ram
Zotac GTX 780 OC, BenQ XL2410T 1920x1080 120hz, LG 29EA73-P 29 Ultra wide
Crucial M4 250gb SSD, 2x3tb Western Digital Caviar Black partitioned into 1.36tb each, Razer Black Widow 2013 edition, Razer Deathadder, Logitech G13.
