I've had the Dell AW3225QF for about 10 months and it has been great. Since I recently got a 5070 Ti to replace the 4070, it feels like I've noticed VRR flicker more often than before. I can only speculate as to the cause. With the higher performance, am I amplifying the differences between averages and lows, inducing the VRR flicker more often than before? With the 4070, I only ever saw it during some loading screens so it didn't matter. But now I see it sometimes in game menus in particular.
Debating solutions to this. I'm not sure a fps cap would work, as I get it even in games locked to 60fps. It looks like 1% lows drop to around 48fps which is causing it. I tried turning off G-Sync, so no VRR at all, and that seems to work apart from I can feel the latency increase from V-Sync. 240 Hz is still a bit low for that. I don't play highly latency sensitive games.
Wait, I just re-checked the VRR range of my display. It is 49-240. Maybe lows are dropping below that so it enters/leaves VRR mode. Not sure what to do with this info right now.
Any thoughts?
https://linustechtips.com/topic/1605130-oled-vrr-flicker/
It can happen any time when you get big fps changes, doesn't matter if it's during gameplay, in menus or loading screens. Maybe you started to notice it more because of a specific game you didn't play before. When switching from a 3080 to a 4080 I didn't see any change in VRR flicker behavior. To me it was never distracting enough to take away from the other advantages OLED brings.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1605130-oled-vrr-flicker/#findComment-16680744
It's happening in games I've been playing for years. Good point it doesn't affect all games. I might try selectively disabling VRR in the worst affected ones.
https://linustechtips.com/topic/1605130-oled-vrr-flicker/#findComment-16680747
3 minutes ago, WereCat said:
Time to enable frame gen? 😄
Don't think any game I play regularly supports it, so injection isn't even an option. You do remind me, I want to try out MFG at some point to see if I agree with what some in the media say about it feeling better than single FG.
https://linustechtips.com/topic/1605130-oled-vrr-flicker/#findComment-16680753
13 minutes ago, Lurick said:
Do you have Dynamic Refresh Rate enabled in Windows by chance?
That's off.
Also the setting in Nvidia is for full screen only. If I have windowed enabled it makes the desktop flicker when a game is running and other situations. This one isn't limited to OLED I think. I saw similar on IPS panels in the past.
https://linustechtips.com/topic/1605130-oled-vrr-flicker/#findComment-16680777
It's a known issue for OLED, and honestly there is no way around it. I just choose to accept the fate and leave the option off. Screen tearing, on the other hand, is a non-issue nowadays.
PC: Corsair SF1000 | FormD T1 V2.5 Black | Asus B850I ROG Strix | AMD Ryzen 7 7800X3D | 32GB 6000MHz Team T-Create | Asus RTX 4080 Super ProArt OC | Samsung 990 Pro 2x 2TB | MSI MPG 271QRX QD-OLED
Gear: R Λ Z Ξ R Viper V3 Pro | HHKB Professional HYBRID Type-S Charcoal Blank | Artisan Hayate-Otsu Soft | Hifiman XS Edition | JDS Labs Atom+ Stack | RØDE PodMic | RØDE AI-1
https://linustechtips.com/topic/1605130-oled-vrr-flicker/#findComment-16680826
From title I was about to ask what fps range and such, for sure happens at lower. Also are you in dark where you notice it more.
I have not notice any flicker yet on my 32" LG though. I wonder how game dependant that may be.
| CPU: Ryzen 7 7800X3D | MOBO: AM5 B650 Aorus Elite AX | RAM: G.Skill Trident Z5 Neo RGB DDR5 32GB 6000MHz C30 | GPU: Sapphire PULSE Radeon RX 7900 XTX | SSD: Samsung 9100 PRO 1TB with heatsink | Cooler: Arctic Liquid Freezer II 360 | PSU: Seasonic Focus GX-850 | Case: Lian Li Lanccool III | Mousepad: Zowie GTF-X  / Vaxee PC / PA / Artisan Raiden Mid XXL| Mouse: Vaxee XE wired / Hitscan Hyperlight | Keyboard: Wooting 80HE zinc alloy raw - geon raw HE switches | Headset: Beyerdynamic MMX 300 (2nd Gen) | Monitor: LG 32GS95UV-B OLED 4K 240Hz / 1080p 480Hz dual-mode | OS: Windows 11 |
https://linustechtips.com/topic/1605130-oled-vrr-flicker/#findComment-16681024
