Hey guys,
I've done a thread asking for the best water cooling colour scheme and I got mixed results. The fact of the matter is that its all subjective and its up to the builder. So I thought about this for a bit and have decided on a few colour schemes. Here is the few:
  • White accents, Silver blocks, Black overall
  • Yellow accents, Gold blocks, Black overall
  • Mix of Black and White with some colored LEDs lighting up the system.
So, this is simply what I've come up with so far. Its not much but I hope its an idea.
I anything else is ok too. I dont mind.
The only thing about water cooling is that I don't really like red and/or green. Why? because there is too much of it and the image with builds like these is that they all seem as if they're overdone. Especially green (No Offence meant). Also, Red feels like its too overrated. Just all my opinions thou.
Would be greatly appreciated if you guys could help me out here.
If not, that's fine too. I came here to kindly ask for suggestions, not to demand them.
Thanks in Advance,
https://linustechtips.com/topic/159285-water-cooling-scheme-suggestions/
i would go silver fittings, clear tubing, white coolant, and black blocks if that suits you.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
I think white tubing looks better than white fluid in clear tubing...
You don't get the shiny transparent lining that the clear tubing does :\
I think white tubing looks extremely ugly.
http://i236.photobucket.com/albums/ff205/RobBezanson/Newbix%20Cube/DSCN0886.jpg
The coolant will look good I think
I think they look pretty similar...
Clear tubing only looks good as long as it stays clear and doesn't cloud. Also with clear tubing you can see the fluid flow when you're filling/draining :)
But make sure your fluid is pure white, not a yellowish white or watery white :P
Hey guys,
Thanks in Advance,
Look at my loop :) black and yellow  its in my sig
I was gonna recommend mayhems. I'm going pastel red and clear tubing with my build. I think it's cool to see the fluid going around
So, if it came down to having a black mobo I would go for it. the thing is. I've seen this board but the orange accents have been bothering me
it makes it look off. imo. http://www.newegg.ca/Product/Product.aspx?Item=N82E16813128723&cm_re=z97_gigabyte-_-13-128-723-_-Product idk. do you think your suggestion would integrate well with this board?
I heard that stuff other than distilled water. (especially those liquids with all sorts of stuff. I've seen some that look like "shampoo" as one newegg host quotes). eh. just what I've heard thou. White tubing would be a good option, but It would prolly not look as good. eh, my opinion.
opps, I guess someone has beat me to the table.
just my concern, I was worried about that. I guess I stated above about those strange coolants that look like they have particles floating in em.
hmm. interesting. I think I'm seeing a pattern in builds.
not to mention yours specifically, I think I'm starting to get the idea of water cooling builds. They should generally have 3/max 4 colors in em. it makes them look clean. So I think as long as the colours don't conflict. It'll look fine.
http://www.pcr-online.biz/_media/images/gold-pc.jpg
hmm. I guess I could consider that. I'll try doin some research on those. not too familiar with the computer water cooling scene yet.
My personal preference for water cooling is as follows
Blocks: EK
Radiators: Aquacool
Reservoirs:  idk. heard the t virus looks cool
Pump: Swiftech
Coolant: ....Mayhems the only name I hear all the time.
Blocks: EK
Radiators: Aquacool
Pump: Swiftech
Yeah to many colors and it starts to look to busy and ive removed all the spare colors i could leaving me with black, yellow/gold, and blue accents on the back of the lightning cards
Hey guys,
Thanks in Advance,
Finding the gold blocks maybe a bit hard but it sure would look good on the new z97 ASUS motherboards.
A water-cooled mid-tier gaming PC.
