Best white 240mm AIOs for Ryzen 7900X?
Go to solution Solved by Somerandomtechyboi,
thermalright frozen prism
it does have rgb but you can just set it to white or turn it off (imo itd look better if set to white)
I am looking for a white 240mm AIO that can cool the Ryzen 7900X. This is a very space conscious compact build so the case cant fit anything bigger with all the other parts in the position they are in. Thicker radiators like the one on the Arctic Liquid Freezer III wont fit because of the motherboard shroud/VRMs. I dont care about RGB but dont want any LED screens on the cooler. If it has RGB i can just turn it off. What are some good options?
https://linustechtips.com/topic/1585772-best-white-240mm-aios-for-ryzen-7900x/
Just to confirm 280mm not an option?
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
Just now, ImServs said:
rad too thick wont fit
Really. Not even in the front? Whats the max thickness?
Gaming PC:
Linux PC:
7 minutes ago, ImServs said:
its a compact case, it only supports top mounted rads. only standard rad thickness will fit
So is the case not the one you got on your profile Phanteks NV5? If not maybe post what case you got.
If it is NV5, then use this as reference.
Edit: And this:
arctic-liquid-freezer-iii-v0-v6la6nfnbek
Gaming PC:
Linux PC:
6 minutes ago, ImServs said:
Lian Li A3
From this review, you can see that the H100i RGB Pro XT fits, its 27mm. Just like the Frozen Prism 240, @Somerandomtechyboi mentioned.
https://uk.pcmag.com/pc-cases/152485/lian-li-dan-a3-matx
https://www.thermalright.com/product/frozen-prism-240-black-argb/
Gaming PC:
Linux PC:
the frozen prism is definitely my main choice at the moment. Thanks for you help!
If you can get the Frozen Notte or Frozen Magic Scenic V2, they're quite good and have a hidden refill port. They come in white and you can turn off or labs the LEDs unplugged, which is what I do.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
does the frozen prism have a refill port aswell?
You can crack the cold plate and take it off to refill.
You cant go wrong with their newer designs either.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
I'm not sure. For those two, they're hidden under a color matching sticker.
With mine you can. Its probably quieter than the older one too.
Haven't bought one yet 😛
Edit:
Sorry no fill port on mine, but the CP comes off NP.
Edit:
Can what?
I still want a Turbo Right.
17 minutes ago, TPCEA said:
Can what?
The cold plate can come off no problem
I did for awhile too, but it shared the pump with another brand I think, but had copper in the rad. Kind of a turn off for me.
For 70 something beaver bucks, this is probably the best cooler that I have bought. I have beat on it quite a bit over the last year.
The rest of my system fans came from the heatsinks that are in their boxes lol 😄
