need help choosing an AIO
Solved by TPCEA,
Take a look at these results from KitGuru. A dBA chart and 3 AMD charts (also 3 Intel charts at the bottom). Or AIO Monster Showdown - Nov 2023
HWBusters, which is multi-page: noise tests, frequency plots (spectrum analysis) for fans and pumps + noise recordings; normalized noise tests (AMD is on the 2nd half), and AMD conclusion. I think he only recently added AMD to his testing as there are almost no AIOs listed for it, but the LiqMaxFlo is listed.
DerBauer: We're testing the Most Popular AIOs in Germany - And one Failed the Test
HW Canucks: The Ultimate 240mm AIO Roundup for Intel & AMD
