Help to make a statistical ppt better
Solved by Eigenvektor,
14 minutes ago, manikyath said:well.. there's this "rule of thumb" to not have more than 7 lines ona slide, and not more than 7 words per slide.
I think you meant 7 lines per slide and 7 words per line
They general idea is to keep slides simple, you want them to visualize what you're talking about, without distracting the listeners. If the information on a slide requires too much time to parse, people will read instead of listening and miss the actual presentation.
