Upgrade Recommendation From Poco F1
On 4/11/2024 at 8:46 PM, Agent Squirrel said:I'm eyeing Pocophone X6 Pro, which is well under my budget, what do you guys think about it?
Looks like a good choice though you wont be able to do custom roms and stuff cause mediatek so complete nono in that regard, but if you dont intend to run custom roms or recoveries then looks like a solid phone though tbh id still pick the f5 or f5 pro/k60 instead
But if you are already looking at a mediatek phone why not the xiaomi 13t pro instead? Basically a flagship killer so id expect a better display camera and audio compared to the poco x6 pro and as a bonus the soc is also better seemingly abit better than an 8 gen 2 cpu wise
Unfortunate that you cant custom rom and modding is hard on mediatek phones considering how cheap they are and now their dimensity chips are really good and actually compete or outright beat snapdragons compared to their helio trash from years ago, id go dimensity no questions asked if it werent for no custom roms
Btw what country?
And where are you buying from?
