Best Headphone In a Small Budget?
WaitforAmpere?
I'm on a relatively tight budget and these are some of the options:
Rapoo VH710
Asus TUF Gaming H3
Fantech Tamago WHG01 Space
Edifier G2II
Eksa Starengine Pro
Vertux Havana
Edifier G4
Fantech Sonata MH90
If none of these are good, don't hesitate to say.
Honestly I wouldn't trust any of them headphones, what are you looking for? Budget, wired or wireless, mic or no mic etc will all help narrow down your search
something i can comm in games with that wont sound like shrieks of the damned, also something that will help me hear in-game sounds clearly or atleast relatively clearly given the relatively small (around $50 budget i have).
The answer i'd give is a Koss Communication headset or maybe a wired HyperX Cloud, there isn't many reputable headsets out there and the good ones cost a lot of money unfortunately
The HyperX stuff is not so great now, as HP bought them and HP'd up basically.   Reports on new HypterX Cloud headsets are not that positive.
what about the Audio-Technica ATH-PG1  $59 on amazon right now..
