Help me decide - 144Hz, 280Hz
By
Rixon
in Graphics Cards
in Graphics Cards
Solved by Shimejii,
Really depends on how good you are and if you are into competitive play. If you are just a casual, theres really not much of a point over spending.
Is there a big difference? Depends on your eyes and how you handle it. I see the uplift going from 144 to 240 to 360 hz, some people its not as noticeable. The response time is better so that will be an improvement, but unless you are able to actually utilize it, not by much.
Featured Topics
ItsHunterM8 ·
Posted in Troubleshooting0 -
1
3
2
2
Worstcaster ·
Posted in Peripherals2 -
4
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
