Power supply PG value? huh?
33 minutes ago, Average Nerd said:PSUs with a PG value of <100ms can also use similar trickery as described above, and should also be treated with caution. Other than that, I don't see anything inherently wrong with this statement.
I mean, at this point... if we are buying a power supply cheap enough to implement a simple delay like this to HOPEFULLY have good rails by the time we output... without actually having to put the money into the actual circuit to test... it seems almost a wash at that point... but 2 cents on capacitors is 2 cents in your pocket, so i get it.
22 minutes ago, seon123 said:The Intel PSU design guide explains why they recommend at least 100ms for the PWR_OK delay
Check chapter 4.3, and Table 4-10. Note 2 for that table. 100ms minimum is recommended for older generation systems.
(It's a .pdf file and I cba copy pasting it properly in text)
It also takes some time for the voltages to rise to the required values, so there should be some non-zero delay before the PSU sends the signal, just because of that.
great point. i hadn't thought to look to intel to have had a hand in the specification. but it makes sense since their CPU's would be relying on the power being smooth and accurate.
so...
assuming a good reputable power supply company's supply under test, the statement,
"PG Values are usually considered normal if it falls within the range of 100ms - 500ms, but a value of 0ms can indicate evidence of an internal power supply failure or trickery to simulate a good supply regardless if the supply is good or not. Power supplies with values over 500ms should be treated as highly suspect, with 1ms to 99ms being a gray area with regards to compliance with modern motherboards, but may be acceptable on older systems."
seems pretty accurate now (your kilometerage may vary i am not an engineer warranty is 2 part if it breaks you keep both parts all rights reserved etc.etc.etc.)
but also.. in addition, if testing an unknown/unusual/noname/offbrand brand or manufacturer supply under test, the statement
"These types of "value" PSUs may return with a PG value of anywhere from 1 - 500ms regardless of the actual power condition, and could be cause for concern due to the manufacturer trickery regarding the power good testing process, and should be treated with caution. As a matter of course, value power supplies should be changed regardless of PG value."
could be added and allies as well.
I think I understand this now, thank you all for your input and help!
