6 minutes ago, Hylkedu said:
What settings? also is the CPU usage again at 100%?
4 minutes ago, Hylkedu said:
aah i understand now! thanks for explaining
i tried using both slots but same outcome
Have you set the PCIe slot width to the highest it can be? PCIe 3
Should be that as stock though
@Agall
Any ideas?
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
@Agall
Any ideas?
where can i check the width?
and normal setting i should run this game on 200fps plus
CPU usage? same?
keep it in the top slot but should be fine
you could try doing a CMOS reset
try contacting Gigabyte support because I'm stumped
Total: £1040.95
GPU-Z while having a game in the background will show PCIe version, from a previous entry, it looked like it was running at PCIe 3.0 16x, but GPU-Z is a bit more definitive with a game in the background.
Have you tried using a standard 2x8pin VGA connector with the included adapter? I'm assuming you're running a 1:1 12VHPWR connector currently, which I've seen weird bugs with myself.
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
1 minute ago, filpo said:
CPU usage? same?
cpu usage is indeed 100%
i also tried a 2x 8 pin connecter with the adaptar
Is the CPU usage 100% from the application alone? If you sort by CPU in Task Manager, it'll show what's using CPU threads. If you're at 100% without the boost clock being upwards of 5GHz (shown in the Performance section) then there's a simple boosting issue with those applications.
If you're boosting to 5GHz and still at 100% CPU utilization while having sufficient R23 scores, then there's something messed up software wise with the scheduler or some sort of malware. If the application is taking up a majority of that usage, being your game is >50% alone, then that just simply doesn't make sense for a 10900f sufficiently boosting.
I personally think it's the motherboard. What's CPU power like in game while it's at 100%?
Total: £1040.95
so no right now i am playing a game and the cpu is like 50% and the gpu is 13%
if i close evrything it just go to normal standards the cpu
i am not sure what all these 5ghz means i am sorry!
i am so hopeless right now
i even tried going to a computer store and they dont know aswell
i must sday it did not seem like a good comnputer store
It's really hard to diagnose without proper data
If the GPU-Z data in your pic is while gaming, it's clearly not powered enough (max TBP 50W..)
Pls send pics of your rig, esp. GPU and CPU power connectors
Check in GPU Z the PCie gen and lanes (Rebar is mostly a gadget)
10 minutes ago, Hylkedu said:
What @PDifolco was asking for is in the first window of GPU-Z that shows up right after you run the software
It is dynamic though, so open GPU-Z, then run a game, then take a screenshot of the GPU-Z while the game is running on background
Example :
Refresh before you reply
1st vid don't play
2nd one shows GPU is correctly slotted and has the 12pin connector plugged in GPU side, but what's on PSU side ?
1 minute ago, Poinkachu said:
What @PDifolco was asking for is in the first window of GPU-Z that shows up after you run the software
Example :
Ok so it's running correctly lane wise, PCie Gen3 x16, your CPU is Gen3
Need to see power consumption at full load (GPU Z monitoring while gaming), suspect GPU Is power starved for an unknown reason and runs only on PCIe slot pwoer (75W ..)
Badly connected cable ?
Looks fine too...
Try to disconnect/reconnect fully the GPU power cable
Could also try using the ugly 3 to 1 12pin adapter and use x2 PCie 8pin power cables and see what's give
NO loose cable tried recabbeling evrything
2 minutes ago, PDifolco said:
Looks fine too...
tried recconecting the  power cable
keep in mind i used and older powersupply and experienced the same problem
so i thought it was something with the powert aswell so i bought the new one
Video res is crap, can't really read anything even on a big monitor , but I can guess TBP is 45W, so card has no power from the PSU
Try the alternative 2x PCie cables with adapter
Did you try the GPU on another rig (not sure if it has been said in the 3 previous pages..) ?
i tried both thing you mentioned already ealrier
i tried a diffrent mobo slot and i tried the 2xpcie cables wioth adapter
eithewr the card has no power or something softawre stops the card to receive the power
we can disclose some things
1 its not the gpu ( it worked on other devices fine!)
2 its not the powersupply ( new out the box and same result as with older powersdupply)
3 cpu seems working good wwith good temperture
what might be wrong is just 1 thing and its the motherboard either broken or just software not good!
