1 minute ago, Hylkedu said:
this is what i am thinking but i dont know where to look!
in bios, if you know how to enable XMP, checking bios version should be walk through kindergarten as such basic crucial info should be presented at the "front page" of it
current PC:
PC configs I used before:
5 minutes ago, filpo said:
and was that with the 10900f? if so did that work as expected?
check your PCIe lane width for SSD and GPU in bios. Should be somewhere around PCIe device settings in advanced
was it around the same fps as with the 4070 ti? Was the CPU usage at 100% as well?
What're you using to cool the CPU?
maybe if they're on a beta one
@Hylkedu try updating to a previous bios (but not from too long ago) that isn't beta if yours is. Even if your bios isn't beta I'd try it anyway
Also try reseating your CPU, RAM, Motherboard and all power connectors
1 YES it worked as expected
2 not sure how to do this and where to look but i will try
3 yes indeed
4 i use watercooling h150 corsair
5 i updated bios drivers multipile times also from older versions
did you change anything else when you upgraded to the 4070 Ti?
should be in advanced and in a place that has 'PCIe' in it
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
3 yes indeed
Have you run Cinebench R23, single run all core on your 10900f?
Should see around 10500-11000, although that's a huge gap from the 10900k, more than it should be, so potentially even as high as 14000.
Intel Core i9 10900F vs Intel Core i9 10900K : Which one is better? (topcpu.net)
As well as making sure you've fully seated your 2x8pin EPS connectors into the top left of your motherboard when upgrading PSUs. You should have at least 8 pins fully seated, otherwise, you could be arbitrarily limiting the CPU to 100W if you happen to only have a 4 pin seated.
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
ill download it now
1 yes the motherboard and the case! and the cooler!
could be the motherboard then. Case won't affect performance apart from thermals and same with cooler (but you're fine in the thermals side)
try the R23 run first though, tell us power usage and temps while it's going
Total: £1040.95
1 ill try to run the cinebench now!
2 in the topleft of my motherboard there is an 8 pin and a 4 pin connected!
ill download it now
I added this after, but its worth investigating:
I'd ensure 4 + 8 EPS to the CPU power connectors are properly seated on both ends. A machine will POST and be fine with just a single 4 pin plugged in, but it'll TDP limit the CPU to around 100W.
Cinebench R23 should show if that's potentially part of the issue too.
Just now, Hylkedu said:
Is geheugen clock the clock speed? if so it looks low, really low. Wait for the test to finish and tell us the score
Total: £1040.95
i disablde xmp before i did this test!
the points aree 13622
not bad, around what I'd expect. Is the problem in game still happening?
@Agall this is what they got above
Total: £1040.95
yes still like 30 fps on chivalry2 and like 30 fps on battlefield
Don't see your answers about
Mobo slot used
Pcie GPU configuration (to check in GPU-Z)
Pcie limiter (power voltage clock) in GPU-Z too
Have GPU-Z running while a game is in the background to verify PCIe version and feature support like ReBAR.
How was RAM usage in game? VRAM usage?
use msi afterburner's OSD to check
Total: £1040.95
35 minutes ago, podkall said:
Heresy?
I'm thinking, could bios somehow cause an issue like that or not likely?
Possible if it's setup in pcie gen2 X4  or such...but not probable 🙂
Mobo slot used
HI
1 i am not sure what a mobo slot is i am so sorry
2 ill try to run gpu-z
it's the slot you put your GPU in (your motherboard PCIe slot)
Total: £1040.95
