Hello my name is hylke
so recently i build a new pc
evrything went great and the pc powers up so i installed steam and ofcourse some games. so here the problem is i tried running various games and i only get between 20 - 30 fps i installed all the drivers i check the cpu temp this was beteewn 40 and 50 celcious i reinstalled windows reinstalled drivers. in the games the cpu is 100% running and the gpu is between 10 and 30% so i thought it was a probllem with power so i buy new powersupply but the problem was not solved i am going nuts and i dont know what to do if there is anyone who can help me i woulld really appricate this i can talk on discord if you like so we can solve this
I AM SORRY FOR BAD ENGLISH I AM FROM NETHERLANDS SORRY!!
the specs are
Cpu : i9 10900f
Gpu:Gigabyte GeForce RTX 4070 Ti AERO OC V2
Ram: 16gb ram ddr4
Motherboard: AORUS z490 ELITE AC
cooling: h150 rgb corsair
Powersupply: MSI A1000G PCIE5
https://linustechtips.com/topic/1561383-hard-problem-only-professionals/
What games specifically?
This is 100% a software issue, the power supply will have nothing to do with it.
Also use HWInfo64 for monitoring the usage statistics. HWMonitor is known to give false readings fairly regularly, especially on modern hardware (more on Ryzen than Intel, but it still does on Intel), and should be avoided if possible.
14 minutes ago, Hylkedu said:
Ram: 16gb ram ddr4
XMP on?
current PC:
PC configs I used before:
Oh yeah CPU usage can be low because if game only uses 2 threads from single core and the CPU has 20 threads, then that's a small portion of the CPU.
current PC:
dayz chivalary 2 battlefield 2042 cpu usage is high gpu ussage is low
high usage on either component can just mean the game is that more demanding for one piece of hardware than the other,
is the fps/performance good or not? that's really the main concern, usages can mean absolutely nothing if the PC is crunching approximately the amount of fps it's supposed to crunch
current PC:
i have 50 fps on battlefield 2042
so no
my old pc was outperforming this one
so no
check out the HwInfo64, it can check some of the things HwMonitor doesn't really do
current PC:
Let me quote someone, I can't really check it out rn,
@Dedayog @filpo @PDifolco
current PC:
7 minutes ago, Hylkedu said:
10 minutes ago, Hylkedu said:
okey i download it not sure tho where to look and where to look for
when you open HWInfo64 you have to open the sensors only to see the metrics. Then it'll be on a table showing CPU usage, temps and the rest
what resolution?
nope, it's a problem with the CPU/software (bottleneck or drivers/bios isn't updated)
thank you so much for the help already this means alot to me i even tried bringing it to a computer store and they could not find the problem so this is going to be hard i guess so i really appricate your help already
do you know how to update your drivers and bios? also have you installed your chipset drivers?
Ram: 16gb ram ddr4
what speed? you can check in bios
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
what resolution?
Resolution is just
1920 x 1080
yes i uodate drivers and bios
chipset drivers i am not sure
soeed ram is 3200
look @RONOTHAN##, they got HwInfo juice data
current PC:
Just now, Hylkedu said:
Resolution is just
1920 x 1080
have you got any other CPU or GPU to use? It's unlikely it's a CPU bottleneck since that's still a decent CPU
(4070 ti is better than a 3090/Ti but they're quite close in performance)
even in CPU intensive games it doesn't bottleneck it that much
soeed ram is 3200
try disabling XMP and manually setting the speed to 3200
Resolution is just
1920 x 1080
Was the CPU pegged at 100% in game all the time?
there should've been something in the manual saying to install your chipset drivers in the motherboard box (and a CD with them on it, might also be a website or USB if it's a really high end board)
Total: £1040.95
hey so my previous gpu was a 2080ti  and now i have a 4070ti
Yes the cpu was pegged at 100 in game all the time
ill try to disable
i tried putting a 1080 in and it did the same! it was same fps very low and also did not work fully
i dont have a other cpu
i also put the 4070ti in a other device and it worked fine!
i will try to disable xmp
6 minutes ago, rwdfsawe said:
Hi did you fix the problem?if not a friend had the same issue in his case the motherboard was the problem i thik since when he swapit it the problem was fixed.
no not yet!
so if this would be the problem the motherboard would just not work proper? how can i assure this!
so no
Yeah pretty crappy
In which mobo slot is the GPU?
Heresy?
Just now, PDifolco said:
Yeah pretty crappy
I'm thinking, could bios somehow cause an issue like that or not likely?
current PC:
and was that with the 10900f? if so did that work as expected?
check your PCIe lane width for SSD and GPU in bios. Should be somewhere around PCIe device settings in advanced
was it around the same fps as with the 4070 ti? Was the CPU usage at 100% as well?
What're you using to cool the CPU?
maybe if they're on a beta one
@Hylkedu try updating to a previous bios (but not from too long ago) that isn't beta if yours is. Even if your bios isn't beta I'd try it anyway
Also try reseating your CPU, RAM, Motherboard and all power connectors
Total: £1040.95
no not yet!
Well is his case was no obvious sign he just changed tthe motherboard because he tried other things that nor work and he did have another motherboard from an old pc.
