How many fans can I connect to my current Motherboard?
Solved by RevGAM,
Fans usually have the max draw shown on the hub label. If not, the box they came in or the website should indicate the max current. Case fans, even if they are the same model number as those sold alone may not be the same, though, such as the FC120 on the DeepCool LS AIO, which are stronger than the same model stood by itself.
Most headers provide 1A max, so make sure that the total doesn't exceed that, unless you're plugging a powered hub into it, in which case you follow its instructions.
