Does an RGB Fan hub power the fans?
Solved by PDifolco,
4 minutes ago, drab said:Great thanks, another question. It came with a 2 cables, one that i assume plugs into the rgb header of my motherboard. Do I plug the other one into my motherboard fan header?
Edit: The cable looks like one that comes off of a fan to power it
Yes indeed, plug it to a fan header on the board
Featured Topics
kazimalizaidi ·
Posted in Cooling1 -
d3mueller ·
Posted in Troubleshooting0 -
JangerBanger ·
Posted in PC Gaming0 -
4
kuzzikan ·
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
