Planning for modifying Thincentre A70
Amyra
hello, guys
this is my old pc thinkcentre A70 with E5700 dual core that died
since the sleeper PC exist
why not I'm gonna do the same thing
before doing that I need help planning where should i put the pump if I want water cooling
I want to budget the AMD system here and put 1080 or 1650 as a starting point
any suggestion for putting something else in here
like cooler, fan, pump(if possible)
well I'm gonna put the rad outside of the case
First decide the hardware that will be going in to the chassis as this thing is decently well ventilated of sorts.
Because if it's just efficeint hardware 0 reason to spend like a TON of money on watercooling. Because custom watercooling is NOT CHEAP AT ALL.
I see
what should I do for mounting fans?
