4k monitor: 28" or 32"?
Westingham
When I look around at some of the best rated 4k monitors (for example, on RTings or PCPartPicker), they're almost always 32" monitors. Very rarely do I see a 28" 4k monitor.
Is this because there aren't many 28" monitors made? Or there aren't many GOOD 28" monitors? I currently have a 27" 1080p monitor and I'm looking to upgrade; 28" seemed like a good size and 32" too big but now I'm wondering if I'm missing something somewhere.
Is it maybe the fact that 4k is better suited for 32" rather than 28"?
Any info/advice would be appreciated.
If you do some digging you might notice some monitors can be exactly the same accept for the screen size.
4K is better suited to 32" and above.  Arguably, 1440p is the 32" resolution.
Pixel density on a 28" 4K is indistinguishable from a 1440p 27". Waste of 4K.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Its because at 32 inches going from 1440p to 4K is a more noticable improvement than with 27.
27/28 inch 4K monitors are available just filter screen size on pcpartpicker.
PC Specifications: Intel i9-14900KF, 5.9GHz all core locked, 5GHz ring, 1.45v Medium LLC, E-cores and HT disabled | MSI RTX 4090 Gaming X Trio | Arctic Liquid Freezer II 360 + Thermal Grizzly contact frame | 2x16 G.Skill Trident Z5 7400MHz 34-44-44-34 1T 1.45v (Tuned Subtimings, Hynix A-Die) | Gigabyte Z790 AORUS Elite AX | Windows 10/11 EVGA SuperNOVA 1000 T2 Phanteks P400A (Black non-rgb version, Phanteks T30 fans 3 intake (On AIO), 1 exhaust) | SK Hynix Platinum P41 2TB PCIE 4.0 (Boot drive), Samsung 870 EVO 2TB SATA
Displays: MSI MAG 271QPX 1440p 360Hz 27" QD-OLED | LG UltraGear 27GP950-B, 4K 144Hz (@120hz) 27" IPS
Desktop Audio: STAX SR-007 MK2 Electrostatic Headphones | STAX SRM-400S Amp | Schiit Bifrost 2/64 (NOS mode, USB in, XLR out)
Mobile Audio: Sennheiser IE 900 IEMs using included 4.4mm cable | FiiO KA13 "Desktop mode" Disabled
Peripherals: Razer Huntsman V2 Full size wired with linear optical switch | Logitech G502 Hero
I have a thing that with desktop displays, as I'm buying them for their desktop real-estate, having to use scaling above 100% is completely unacceptable. A 27-28" 4K at native 100% scaling makes UI items simply too small so 32" or larger is necessary.
If ALL you do is play games and you don't like having a large display, that size for 4K may be nice to make use of the extra sharpness but I'd never want it. I'm currently using a 42" 4K OLED and find its amazing.
personally i prefer 27inch for 4k, the ppi's definitely noticeable and usable if you seat close enough.
though the panel is more important and 32inch panels if you include the oled monitors might be better.
it's basically between the 27m2v and the gp27u atm (same panel), almost all of the 2024 4k monitors are 32inch or larger.
you can look up the basic specs of your choice here and see if the panel exists and if so if any manufacturers selling it
https://www.displayninja.com/new-monitors/
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
1440p 32"?
I highly disagree, at normal monitor distance that is. That pixel density is too low.
1440p is maximum 27" for me.
Personally I am running a 4K 32" and I like its size and resolution a lot, even higher resolution would still be noticeable tho but don't need more.
Even at 28" you can notice the difference between 1440p and 4k, without having to focus on it, but difference ofc is smaller. There is still a benefit, but less so than on 32".
Its actually more noticeable in desktop usage, word browser etc than in games, but also more noticeable in games than in movies.
If I personally had to choose:
32": 4k 60hz > 1440p 144hz
27/28": 1440p 144hz > 4k 60hz
If you can't have 4k with higher frequency.
But for OP:
Yes, at 4k, 32" is more common for people to buy, therefore there exist more of them. People getting 27" more often get 1440p monitors. But if you actually think 32" is too large for you, I wouldn't prioritize that because it's 4k over a 1440p 27".
“Remember to look up at the stars and not down at your feet. Try to make sense of what you see and wonder about what makes the universe exist. Be curious. And however difficult life may seem, there is always something you can do and succeed at.
It matters that you don't just give up.”
-Stephen Hawking
If you want to use 100% scale, 28” screen is too small for it, even 32” also kind of small.
To me, 4K is better in around 32” to 42” and 42” is the best for 100% scale in 4K.
For 27” and below, it is best in 1440p resolution. I don’t accept 1440p in 32” as it is not looking good enough due to low pixel density. Also everything look too big on 100% scale.
For 24” and below, then go for 1080p. I also don’t accept 1080p in 27” as it is same not looking good enough due to same reason low pixel density. Same everything also look too big in 100% scale.
PC: AMD Ryzen 9 5900X, Gigabyte GeForce RTX 4090 OC 24G, X570 AORUS Elite WIFI Motherboard, HyperX FURY 32GB DDR4-3200 RGB RAM, Creative Sound Blaster AE-9 Sound Card, Samsung 970 Evo Plus M.2 SATA 500GB, ADATA XPG SX8200 Pro M.2 SATA 2TB, Asus HyperX Fury RGB SSD 960GB, Seagate Barracuda 7200RPM 3.5 HDD 2TB, Cooler Master MASTERLIQUID ML240R ARGB, Cooler Master MASTERFAN MF120R ARGB, Cooler Master ELV8 Graphics Card Holder ARGB, Asus ROG Strix 1000G PSU, Lian Li LANCOOL II MESH RGB Case, Windows 11 Pro (22H2).
Laptop: Asus Vivobook "A Bathing Ape" - ASUS Vivobook S 15 OLED BAPE Edition: Intel i9-13900H, 16 GB RAM, 15.6" 2.8K 120hz OLED | Apple MacBook Pro 14" 2023: M2 Pro, 16 GB RAM, NVMe 512 GB | Asus VivoBook 15 OLED: Intel® Core™ i3-1125G4, Intel UHD, 8 GB RAM, Micron NVMe 512 GB | Illegear Z5 SKYLAKE: Intel Core i7-6700HQ, Nvidia Geforce GTX 970M, 16 GB RAM, ADATA SU800 M.2 SATA 512GB.
Monitor: Samsung Odyssey OLED G9 49" 5120x1440 240hz QD-OLED HDR, LG OLED Flex 42LX3QPSA 41.5" 3840x2160 bendable 120hz WOLED, AOC 24G2SP 24" 1920x1080 165hz SDR, LG UltraGear Gaming Monitor 34" 34GN850 3440x1440 144hz (160hz OC) NanoIPS HDR, LG Ultrawide Gaming Monitor 34" 34UC79G 2560x1080 144hz IPS SDR, LG 24MK600 24" 1920x1080 75hz Freesync IPS SDR, BenQ EW2440ZH 24" 1920x1080 75hz VA SDR.
Input Device: Asus ROG Azoth Wireless Mechanical KeyboardAsus ROG Chakram X Origin Wireless MouseLogitech G913 Lightspeed Wireless RGB Mechanical Gaming Keyboard, Logitech G502X Wireless Mouse, Logitech G903 Lightspeed HERO Wireless Gaming Mouse, Logitech Pro X, Logitech MX Keys, Logitech MX Master 3, XBOX Wireless Controller Covert Forces Edition, Corsair K70 RAPIDFIRE Mechanical Gaming Keyboard, Corsair Dark Core RGB Pro SE Wireless Gaming Mouse, Logitech MK850 Wireless Keyboard & Mouse Combos.
Entertainment: LG 55" C9 OLED HDR Smart UHD TV with AI ThinQ®, 65" Samsung AU7000 4K UHD Smart TV, SONOS Beam (Gen 2) Dolby Atmos Soundbar, SONOS Sub Mini, SONOS Era 100 x2, SONOS Era 300 Dolby Atmos, Logitech G560 2.1 USB & Bluetooth Speaker, Logitech Z625 2.1 THX Speaker, Edifier M1370BT 2.1 Bluetooth Speaker, LG SK9Y 5.1.2 channel Dolby Atmos, Hi-Res Audio SoundBar, Sony MDR-Z1R, Bang & Olufsen Beoplay EX, Sony WF-1000XM5, Sony WH-1000XM5, Sony WH-1000XM4, Apple AirPods Pro, Samsung Galaxy Buds2, Nvidia Shield TV Pro (2019 edition), Apple TV 4K (2017 & 2021 Edition), Chromecast with Google TV, Sony UBP-X700 UltraHD Blu-ray, Panasonic DMP-UB400 UltraHD Blu-ray.
Mobile & Smart Watch: Apple iPhone 15 Pro Max (Natural Titanium), Apple Watch Series 8 Stainless Steel with Milanese Loop (Graphite).
Others Gadgets: Asus SBW-06D2X-U Blu-ray RW Drive, 70 TB Ext. HDD, j5create JVCU100 USB HD Webcam with 360° rotation, ZTE UONU F620, Maxis Fibre WiFi 6 Router, Fantech MPR800 Soft Cloth RGB Gaming Mousepad, Fantech Headset Headphone Stand AC3001S RGB Lighting Base Tower, Infiniteracer RGB Gaming Chair
Well depends on you though I'd say a larger one based on your current. 1080p on 27" is very chunky so 4K on similar to you you will probably want to use scaling. Best would be to check them in person in store to get the idea.
Unfortunately Windows scaling is still not great overall, depends on programs too so always good to avoid. Personally 24" 1440p, 27" 4K in terms of sharpness is what I liked, but those monitors don't exist or few did on 4K side for reasons that high ppi Windows and programs are not supported well.
| Ryzen 7 7800X3D | AM5 B650 Aorus Elite AX | G.Skill Trident Z5 Neo RGB DDR5 32GB 6000MHz C30 | Sapphire PULSE Radeon RX 7900 XTX | Samsung 990 PRO 1TB with heatsink | Arctic Liquid Freezer II 360 | Seasonic Focus GX-850 | Lian Li Lanccool III | Mousepad: Skypad 3.0 XL / Zowie GTF-X | Mouse: Zowie S1-C | Keyboard: Ducky One 3 TKL (Cherry MX-Speed-Silver)Beyerdynamic MMX 300 (2nd Gen) | Acer XV272U | OS: Windows 11 |
