How much volt in the PSU case is normal
6 minutes ago, burgerMan said:Then I am missing the point here..
Why is the PSU sending out volt through the ground if it shouldn't do that? Isn't because something is shorted or something like that?
Thanks for helping me
It's normal for power supplies to have a small amount of leakage current, a few mA maybe. It's usually caused by the EMI filtering on the PSU. Though there can be other causes for it such as a short to the case in the system.
While you have the multimeter out measure the current.
9 minutes ago, burgerMan said:Checked now and here in Sweden it seems like that houses built after 1994 has to have grounded outlets but it doesn't seem to be law to change already ungrounded outlets.
If your kitchen has grounded outlets it should be possible for an electrician to connect the rest of the outlets in the apartment to ground. Assuming the kitchen outlets are actually earthed and not just GFCI outlets.
